dewdew 10 #1 Posted March 12, 2014 I took my carb off after I noticed some gunk build up and cleaned it. No I'm not sure at what point I should set the adjustment pins to reinstall it. Can anyone tell me a way to get it close then I'm thinking that I can fine tune it while it's running. Although I'm not sure that there isn't a better way. Thanks mike Share this post Link to post Share on other sites
SousaKerry 503 #2 Posted March 12, 2014 adjustment pins Do you mean the needle valves? I usually set 2 1/2 turns from finger tight, set the idle screw so the butterfly is just barely open. Start and adjust. Share this post Link to post Share on other sites
rmaynard 17,642 #3 Posted March 12, 2014 Download the Kohler K-Series manual and all those questions are answered. Share this post Link to post Share on other sites
