staticpromo 0 #1 Posted February 10, 2014 I removed my face panel to replace my oil line in my GT 148. I put it all back togeather and now it will not start. I can turn the key and jump the selinoid and she runs. I can turn her off. she just will not start by turning the key. any ideas? Thanks Dave Share this post Link to post Share on other sites
rmaynard 16,700 #2 Posted February 10, 2014 I don't have any experience with that model, but here is a link to a wiring diagram for that tractor. http://www.wheelhorseforum.com/files/file/1008-tractor-1983-gt-series-wiring-detailedpdf/ Share this post Link to post Share on other sites
chazm 413 #3 Posted February 10, 2014 WELCOME TO Did you check for any disconnected wires or blown fuses Share this post Link to post Share on other sites
WH nut 553 #4 Posted February 10, 2014 (edited) Sounds like you need to go back to where the problem occurred. Remove the face plate and make sure nothing came disconnected. Edited February 10, 2014 by WH nut Share this post Link to post Share on other sites
"D"- Man 827 #5 Posted February 10, 2014 If you have an electric voltage tester you could check to see if you have 12 volts at the solenoid when the key is turned to the start position. This may help to narrow it down. Mark. Share this post Link to post Share on other sites
Save Old Iron 1,573 #6 Posted February 11, 2014 (edited) sounds like you may have flexed the starter trigger wire off the ignitin switch or at least repositioned it onto a corroded spot on the "S" terminal on the ignition switch. reseat the wire or clean / replace corroded ignition switch or wire terminals Edited February 11, 2014 by Save Old Iron Share this post Link to post Share on other sites
Don1977 605 #7 Posted February 20, 2014 I would first check the wires to the amp meter as all power to the switch comes through it. I guess you used a screw driver on the solenoid to start it that bypasses the switch. Share this post Link to post Share on other sites
