crm227
c120 automatic--transmission engages...sometimes
crm227
Folks--
Need a little help here. Have a '76 c120 automatic. Starts right up and engine runs great. Moved fine in fwd and reverse at the beginning of the snow season, but past two times I've plowed with it the transmission (or something) has quit on me in the middle of a plow. Usually first happens when I'm stopping to put it into reverse. Might catch a little, but then stops. No noises, nothing else noticeable. If I had to find something to comment on, it would be that the lever to engage the transmission feels like it has less resistance than normal. In the past, I've let it sit for a little and then it's worked. Other times it will start working, then I'll shut it off a minute later and when I restart--nothing. Last night I went to turn it around in the garage and got halfway through a 3 point turn before she just stopped moving. Again--no noise and no engine problems.
One other point--when this happens the tractor can be pushed without having to unlock the push valve. But I've never tried pushing it that way--just noticed that I could. Valve opens and closes fine, but at this point there isnt any noticeable difference when it's open versus when it's close. It's that last point that worries me.
Whaddya think?
Chris
rmaynard
Have you checked the transmission oil level?
crm227
yes--checked it last night and it was within a normal range.
squonk
I'm thinkin you have a worn out trans. I had almost the same problem a few years ago and had to replace the hydro motor. I have a spare transmission that I would offer you for little money but you're kind of far away.
daveoman1966
You MAY have broken the tab that locks the shaft of the motion control lever aparatus.
Look at this pic of my C-160 (same hydro unit) and locate this on your C-120.  This shaft has a tab on the end of it that is bolted to the hoodstand to keep the shaft from turning with the motion control parts.  Very often this gets cracked, then breaks, allowing the shaft to move freely when it should not.
In the schematic, I am referring to item # 6-40.  Look at the little flat tab on the LEFT end of that shaft.
Edited by daveoman1966
daveoman1966
As a 2nd possibility, there MAY be an issue with the FWD / REV valves in the MOTOR section of the hydro unit.  Either could be stuck or the spring between the two valves MAY be broken.
These are located toward the bottom of the Hyd MOTOR on LT side of tractor.  Here are a couple pics...hope they help.  PS...take CARE to keep these CLEAN and be ABSOLUTELY CERTAIN to replace them EXACTLY as they came out.  Don't use a steel object to push the valve and springs out of the cavity.  I use the rubber tip of a pencil and a Magnetic pick-up tool.
NOTE.... These valves have a FLAT surface on them, one FLAT being a bit wider than the other valve.  Be sure you get it right! ! !.
TT
Just because it's easy........
Check the rear wheel hub(s) & axle key(s).
crm227
thanks, all. I quickly glanced at the tab Dave pointed out and it looked fine. Will move on to look at the others next (starting with the hubs and keys). Will let you know what I find.
crm227
Folks-
What exactly am I looking for when I check out the hubs and keys? Any step by step instructions or tips? This is new territory for me.
Thanks
Chris
can whlvr
when the tractor wont move,get someone to look at the axle in the middle of the hubs,see if they are turning inside the hub,which they shouldn't,the axle and hub should move as one,its the key inside the hub that splines them together,if its sheared the axle can spin inside the hub
crm227
OK--a quick update.More snow this week. Crossed my fingers and started her up. And she moved. Didnt give me any trouble. So now I'm thinking that perhaps it has to do with either really cold temps. Does that sound possible? What could be affected by cold like that?
876wheelhorse
my c141 did this. sometimes go sometimes no go. i recall i was moving one day hit a big dirt clod it quit moving. there it sat. my frame was busted got it welded back up and i had a bad hub. both of these are fixed now and this year it hasnt let me down now that i said something its going to be the biggest pile ever...
  • Similar Content
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • Charles99
      By Charles99
      ok I'm new to these and first time really working on small engines. i have a k301 engine. i ordered the tune up kit with new coil, condenser, and points. after installed it won't fire. it turns over that's it. I made sure everything is grounded and the points have proper gap . 20. i have voltage at the coil i have spark at the points. i took the plug out that has spark. I'm not sure what else to do I'm about to start putting old parts back on and see if that changes anything. it did run before hand pretty well actually besides an occasion sputter or hiccup.
    • giant_g2
      By giant_g2
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
