c120 automatic--transmission engages...sometimes
By
crm227, in Transmissions and transaxles
Similar Content
By eo1bart
Looking for a gearbox with 1 1/8" axles for my 312. Ok if it needs rebuilding.
Located in the New England area
By Tim's Toy Tractor
C - Series, Hood and Sheet Metal (square black insert) (also known as black hood models) for sale!
This sheet metal set, including C Series Hood, Dash piece, Seat Bracket, and Left & Right-Side Covers, and Left & Right Floorboards was sandblasted, epoxy primed, and painted the OEM Wheel Horse Red Paint.
The painted set is not perfect, a little metal pitting on one of the floorboards, a few little imperfections in the paint here and there as I'm a rookie painter, but this is a nice painted set of sheet metal to freshen up your C Series Wheel Horse!
$140.00 O.B.O. Call Tim @ 1-313-460-8858 (No Shipping, Local Pick-Up Only)
By cheesegrader
About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
Does anyone remember who made this awesome mod, and where I can find them?
By Charles99
ok I'm new to these and first time really working on small engines. i have a k301 engine. i ordered the tune up kit with new coil, condenser, and points. after installed it won't fire. it turns over that's it. I made sure everything is grounded and the points have proper gap . 20. i have voltage at the coil i have spark at the points. i took the plug out that has spark. I'm not sure what else to do I'm about to start putting old parts back on and see if that changes anything. it did run before hand pretty well actually besides an occasion sputter or hiccup.
By giant_g2
