dewdew 10 #1 Posted February 2, 2014 (edited) So I changed my points and condenser but can't get it running now. Don't know what to do now. I think that it is just fireing at the wrong time Edited February 2, 2014 by dewdew Share this post Link to post Share on other sites
leeave96 487 #2 Posted February 2, 2014 Did you set the gap? Also, you might try Dave Kirk's point saver ignition module with the timing LED. Makes points a friendlier piece of hardware to work with. Here is a link: http://www.kirkengines.com Share this post Link to post Share on other sites
dewdew 10 #3 Posted February 2, 2014 I did set the gap but set it when the plunger was out. I got it figured out, thank you for the reply Share this post Link to post Share on other sites
Fordiesel69 226 #4 Posted February 6, 2014 I did set the gap but set it when the plunger was out. I got it figured out, thank you for the reply Hmmmmmm, the points plunger does need to be out (points open to their full travel), and it should be about .018" or close to it. Share this post Link to post Share on other sites
