dandan111 45 #1 Posted January 31, 2014 Any of you guys use plastic? My neighbor has plastic on his Deere blade. It looked kind of distorted like it got hot. He told me it works great but I have my doubts. Share this post Link to post Share on other sites
Hodge71 691 #2 Posted January 31, 2014 I never used plastic. I can speak from experience not from me personally using one but from the road in front of my farm. Beaver Twp. switched to a plastic cutting edge after they had a driver break a steel one last year…..This new plastic edge sucks. It doesn't clean down to the asphalt and doesn't scrape away chunks of ice or slush away very effectively. I would never use a plastic or rubber edge Share this post Link to post Share on other sites
SAM58 33 #3 Posted February 11, 2014 Never is a long time... Snow removal is best if you plow before it is packed down and turns to ice. Check out this link, they have several to choose from. http://4wheelonline.com/atv/Warn_Replacement_Wear_Bars.203974.1433755 Plastic has it purpose if you don't want big scrap marks on your drive way, probably won't cut ice. Unless you have a solid link & Hyd. lift to apply down pressure, your steel edge won't cut ice either. Use what works! And if it Hurts, Don't Do It. Share this post Link to post Share on other sites
