rustyoldjunk 127 #1 Posted September 8, 2008 took a few bad pictures of the 1257 and 657 side just to compare things. Attached Image Share this post Link to post Share on other sites
rustyoldjunk 127 #2 Posted September 8, 2008 front the side.showing the shorter frame of the 657. Attached Image Share this post Link to post Share on other sites
rustyoldjunk 127 #3 Posted September 8, 2008 from the rear.the 1257 appears to have wider axle shafts and does have wider rear tires. Attached Image Share this post Link to post Share on other sites
rustyoldjunk 127 #4 Posted September 8, 2008 1257 rear. Attached Image Share this post Link to post Share on other sites
rustyoldjunk 127 #5 Posted September 8, 2008 657 rear Attached Image Share this post Link to post Share on other sites
rustyoldjunk 127 #6 Posted September 8, 2008 the hubs are out flush on both tractors,btw.and one from the side of the 1257. Attached Image Share this post Link to post Share on other sites
Kelly 1,028 #7 Posted September 8, 2008 Not sure but it looks like the 657 has the newer style fender on it, it is wider, I thought they started them in 68 or 69, they make the tires look small, really so with the skinny tires. Share this post Link to post Share on other sites
rustyoldjunk 127 #8 Posted September 9, 2008 you're right,Kelly! i wouldnt have thunk it,most everything had had over there was older then '68 so i never paid it much attention,but i just went out and measured and it is the newer fender pan.each axle shaft is about an inch longer on the 1257,thats the amount the hubs are slid out to the ends of the axles.the 657 hubs sit flush on the end of the axles with almost no gap between axle housing and hub. Share this post Link to post Share on other sites
Kelly 1,028 #9 Posted September 9, 2008 I might be wrong one the years they started the wide fenders, but my 857 has the narrow ones, (short frame) and my 1969 workhorse has the wide ones also a short frame. Share this post Link to post Share on other sites
BPjunk 184 #10 Posted September 9, 2008 Kelly, Your correct it was 1968 for the first year of the wide fenders. And for those who THINK a NOS round hood is exspencive ... try to find a NOS small rear fender for a 1965 to 1967 Wheel Horse. <_< Wild Bill in Richmond, Va. Share this post Link to post Share on other sites
