Eric857
Broken line
Eric857
Hello Redsquare,
I was just working on taking apart me engine when the little metal fuel line that runs from the fuel pump to the carb broke. The rubber on the end inside the bolt was old and hard and snapped off. Is it reapairable? Can I replace it?
Thanks,
Eric
chazm
Here ya go... I stole the info from one of TT post  :eusa-shhh:    :hide:
Fuel line "sleeves": (Kohler) 220547-S  :handgestures-thumbupleft:
rmaynard
If you need the whole 3-piece fitting, don't get it from Kohler, you will pay many times more than they cost if you by them from the OEM manufacturer.
The fitting is called a Vibra-Lok fitting. Made by Parker Hannifin. Part # 68VL 3-2. It comes with the male fitting, the female nut, and the rubber gasket. All for about $4.00.
  • Like 4
Eric857
So I get 2 of this and put my metal line in and it will just stay, the other rubber fitting was attached somehow.....
rmaynard
Yes. As you tighten the nut, the rubber gasket compresses around the 3/16" fuel line and holds it in place. The idea behind the rubber is to provide an anti-vibration damper. Later, gas lines were replaced with neoprene. Since they had them from the gas tank to the pump, I don't know why they just didn't use them from the pump to carburetor as they did on later engines.
dclarke
Did not know that..... Thanks Bob!
  • Similar Content
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
