bmsgaffer 2,043 #1 Posted January 21, 2014 I am replacing all the fuel line on my C-125 tonight and adding a fuel filter. I just didn't know what size to buy (probably going to electric fuel pump while I am at it). I forgot to grab any to compare to before I left for work and I was hoping not to stop home first. Second, the spring on the throttle/governor assembly looks a little old and is loose when the throttle is down. Is that something I can source locally? (napa, auto zone, o'reilly, etc are all close) If so do you have a part number? Thanks! Share this post Link to post Share on other sites
varosd 1,185 #2 Posted January 21, 2014 fuel line 1/4 inch Share this post Link to post Share on other sites
smoreau 658 #3 Posted January 21, 2014 if its going to full rpm correctly, it may you need to adjust the throttle cable to take up the slack. Share this post Link to post Share on other sites
bmsgaffer 2,043 #4 Posted January 21, 2014 if its going to full rpm correctly, it may you need to adjust the throttle cable to take up the slack. I actually think its over-revving if I go all the way up on the throttle. Share this post Link to post Share on other sites
smoreau 658 #5 Posted January 21, 2014 you might have a broken weight on the governor. How to Set the Governor Adjustment - Top of page If your engine revs with no closing of the throttle shaft, or surges, then the governor is probably out of adjustment. To set the governor on a Kohler (or virtually any engine)... Install all the throttle linkages, governor parts, etc., in their respective places. Loosen the bolt that clamps the lever to the governor cross-shaft that protrudes out of the engine block. With the throttle plate blocked in the wide open position, rotate the cross-shaft counterclockwise until it stops. Now tighten the bolt. That's all that's to it! But if this doesn't fix the problem, then perhaps a governor part inside the engine is damaged or the screws came out of the throttle plate, where it fastens to the throttle shaft. And it doesn't matter how long or short the link is because the governor is adjusted by the clamp on the cross shaft. Actually, I don't know why Kohler made the link adjustable. It serves no purpose to lengthen or shorten it. You can also go here for further details and pictures: http://cubfaq.com/govadjust.html. And to set the high rpm governored speed, place one end of the governor spring in the middle to lower hole in the "L" shaped governor lever, and place the other end of the spring in either the top or second hole from the top in the short lever that's located under the carburetor or on the flywheel shroud. It's best to use a [Dixson] small engine tachometer to determine the exact rpm to prevent over-revving of the engine, which could cause the connecting rod to break. (Double the reading on the [Dixson] tachometer on engines with camshaft-operated ignition points.) The high speed governor limit for a stock engine is set at 3,600 rpm. For a stock pulling engine, set it at 4,000 rpm, or whatever sanctioning rules require. Do not mistakenly rotate the cross shaft clockwise (opposite rotation than what it shows in the drawing above) until it stops, tighten the clamp and then run the engine! Doing this could cause the lever (see below) to jam into the governor flyweights, breaking off the lever and/or possibly destroying the governor gear assembly. If the governor cross-shaft (the shaft that protrudes from the block) gets bent due to rough handling of the engine, and if it's not bent too bad, just use a hammer to straighten it. It's made of mild steel. But if it's bent severely and breaks off, it must be replaced. If this happens, usually the bushing/nut (Kohler part # 235476) will break and it will need to be replaced, too. Or, if the above adjustment was attempted, and the governor shaft keeps rotating without stopping, this means the flat lever on the shaft has broken off. This will allow an engine to operate dangerously at wide open throttle at all times. To fix either of the above, another governor shaft (Kohler part # A23525601S) must be installed. To install another shaft, the entire engine must be completely disassembled. This means EVERYTHING inside the engine block (crankcase) will need to be removed. And then the replacement shaft can installed from inside the crankcase. But before the old shaft is removed, the bronze bushing/nut on the outside must first be removed. The governor gear assembly doesn't have to be removed. The shaft lifts out from inside the crankcase and is installed in reverse order of removal. And it'll be a good idea to place a small bead of weld on the flat lever to secure it to the shaft to prevent future breakage. (I think this is something that Kohler should have done.) I realize that this is a lot of work just to replace a small [important] part, but it must be done in this way. There is no other way to replace it. Share this post Link to post Share on other sites
bmsgaffer 2,043 #6 Posted January 21, 2014 you might have a broken weight on the governor. Thanks for the tips, I will try adjusting it tonight. I think the governor itself is OK, because the tractor can handle changing loads (plowing and up/down hills) and keep a relatively steady RPM. If my rewiring and fuel line fix don't solve the problem tonight I will post video of it. Anyone know on the spring? I do want to replace it just for my comfort, i does look tired and could even be the wrong size. Share this post Link to post Share on other sites
