fourwheels0 191 #1 Posted January 20, 2014 i need help finding parts for my h55d. it's from my 1961 551. engine number is h55d-2113 and the other number is 9820946 i need point's (or part number) or possibly the whole set up. Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted January 21, 2014 I am reasonably sure that the H60 points are the same. I'll see if I can find my notes with more information. 2 Share this post Link to post Share on other sites
sorekiwi 761 #3 Posted January 21, 2014 The part # that I used on mine was Napa 7-01024. 1 Share this post Link to post Share on other sites
fourwheels0 191 #4 Posted January 21, 2014 (edited) sorekiwi thanks. i'll check with them tomorrow maybe (we are expecting snow). Edited January 21, 2014 by fourwheels0 Share this post Link to post Share on other sites
oldredrider 2,553 #5 Posted January 21, 2014 sorekiwi thanks. i'll check with them tomorrow maybe (we are expecting snow). Snow shouldn't be a problem since you have snow tires...They're in that BIG Merc trunk! 1 Share this post Link to post Share on other sites
fourwheels0 191 #6 Posted January 21, 2014 sorekiwi thanks. i'll check with them tomorrow maybe (we are expecting snow). Snow shouldn't be a problem since you have snow tires...They're in that BIG Merc trunk! there's one in every crowd lol (usually it's me haha) that's ok though if i can't drive anywhere i'll take the quad out for some fun in the snow lol Share this post Link to post Share on other sites
fourwheels0 191 #7 Posted January 23, 2014 sorekiwi nope those points from napa are not the right ones. the search continues thanks though. Share this post Link to post Share on other sites
fourwheels0 191 #8 Posted January 23, 2014 here's the set up i have Share this post Link to post Share on other sites
sorekiwi 761 #9 Posted January 23, 2014 Sorry about that. I just reviewed my notes and realized that my motor (from a 502) was an HT55A-3088. The points must be one of the differences. Probably no help to you, but I did find a picture of some H60 points that are different again: Share this post Link to post Share on other sites
fourwheels0 191 #10 Posted January 23, 2014 yup sure enough those are the points i got and they are too small. the difference between the pin and mounting screw is longer on mine and the wire connecter is on top. Share this post Link to post Share on other sites
formariz 12,381 #11 Posted January 23, 2014 Your engine should have a WICO 29692(FW2681) magneto. All h55d spec 2113 engines i have do so. Points are Tecumseh part #28524, condenser is Tecumseh part #29559. Both not easy to find. 1 Share this post Link to post Share on other sites
formariz 12,381 #12 Posted January 23, 2014 Incredibly there are quite a few of each on eBay right now. I suggest getting a couple of each. Share this post Link to post Share on other sites
fourwheels0 191 #13 Posted January 23, 2014 formariz thank you for the info. Share this post Link to post Share on other sites
fourwheels0 191 #14 Posted January 26, 2014 ok we got new points and still an issue. i'm about done. looks like the coil is bad. if i can't find a complete good ignition set up i'm putting a clone in it. so does anybody have a good complete ignition set up for a Tecumseh h55d-2113. Share this post Link to post Share on other sites
formariz 12,381 #15 Posted January 27, 2014 Unless you get anther h55 that is not going to be easy or a fat fix. I assume you are not getting spark? Share this post Link to post Share on other sites
SousaKerry 503 #16 Posted January 27, 2014 Replacement coils are available, but as you know this is the weak spot for most Techy's. An old school JD mechanic told me that when they had one with weak or no spark the best solution was to mount a Kohler coil externally but use the Techy point setup. Of coarse this may not be an option if you want the original look and you must have a working charging system as well. None of my tractors have working charging systems so I have not yet tried it. Another option would be to locate a mag from an H60 with charging coils and retrofit, it should have no problem bolting up and then your parts would be more common. Check the gap between the coil and the magnets it should be as close as possible without hitting, this is not easy but a procedure for this is in the Techy manuals. Clay or playdoh/silly putty can be used to measure the clearance. Once you have the gap set then you will have to re-time the points. I actually do this on the bench much easier then bent over the tractor. Share this post Link to post Share on other sites
fourwheels0 191 #17 Posted January 27, 2014 (edited) well thanks guys but this has come to an end. i found a lot more issues with the tractor. broken frame and broken rear end. if i fix the tractor it will get a clone. Edited January 27, 2014 by fourwheels0 Share this post Link to post Share on other sites
SousaKerry 503 #18 Posted January 27, 2014 Ouch Looks like some kids thought that poor Wheel Horse was a 4 wheeler... If your going to abandon the project at least make sure it can give it's internal organs so another can live. 1 Share this post Link to post Share on other sites
fourwheels0 191 #19 Posted January 27, 2014 well my buddy put the Tecumseh back together and now it runs. i have no clue or idea what's going on but it's running. Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #20 Posted January 28, 2014 Looks like it got dropped off a truck..... a very high truck. 1 Share this post Link to post Share on other sites
fourwheels0 191 #21 Posted January 28, 2014 to me i think somebody backed into it with a truck while it was against a wall or something. never seen anything like it and i've seen some beat up machines. i took a major bath on this one but it will live again. the rear case is shot too. Share this post Link to post Share on other sites
fourwheels0 191 #22 Posted February 4, 2014 what is the value of a complete good running h55d-2113. comes with stock exhaust and heat shield. we've had it running 3 times and runs good with no smoke or noises. i'm thinking of selling it. Share this post Link to post Share on other sites
