MrMilkgoats 0 #1 Posted January 20, 2014 Hi - have a 416H and have been using the blade to scrape snow. It seems to travel faster in reverse than forward. Is there an adjustment for that? Thanks! Brad Share this post Link to post Share on other sites
stevasaurus 23,857 #2 Posted January 20, 2014 You need a hydro guy to step in here...wish I had the answer for you, but this will bump your thread up to the top. Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #3 Posted January 21, 2014 Lift the seat and looks at the mechanism just below the square hole in the rear fender. Is everything in that area clean? Dirt can build up around the speed control arm on the hydro unit and in the slots of the cam, limiting the travel. What is the model number of your 416? 1 Share this post Link to post Share on other sites
smoreau 658 #4 Posted January 21, 2014 Sounds like the cam came loose and spun around.its located under the seat. Had this happen to me a few years ago. 1 Share this post Link to post Share on other sites
MrMilkgoats 0 #5 Posted January 21, 2014 Hello - and thanks. The model number is 73421. The mechanism under the seat is clean. Brad Share this post Link to post Share on other sites
smoreau 658 #6 Posted January 21, 2014 down load this link and it will show you how to adjust this cam plate. http://www.wheelhorseforum.com/files/file/1261-transmission-automatic-eaton-11-1100/ 1 Share this post Link to post Share on other sites
