6.0 powerstroke
any plumbers? watts valve ?
6.0 powerstroke
I have a pressure gauge on the water line after the watts pressure reducer. Right now the gauge is pegged at 130psi . I tried adjusting the nut to lower it, but there was no change. Open a faucet and psi goes 65, whwhere it should be.
Am I right that the valve has gone bad? That psi should be much lower after the valve?
SousaKerry
Yeah normal house pressure is like 35-55 PSI.  Sounds like a bad pressure regulator, the drop in pressure when opening a tap is because the flow is restricted through the regulator.  Probably due to it being partially stuck open or a busted spring.  I have never messed with a water pressure regulator but have worked on plenty of Steam and Air.
shorts
could be a guage going bad, I would replace both the guage and valve to play it safe, the parts are way cheaper than a burst water system and the resulting water damage and cleaning up the mess
Edit, Kerry beat me to the post,
Edited by shorts
6.0 powerstroke
im going to get one either tonite or tomorrow. I wasn't 100% sure how they worked
we started getting a high pitched sound with the upstairs faucets that only lasted a few seconds and stopped., then wouldn't come back for a while.
im figuring that this is the cause   the pressure is too high through the pipes , it drops down when the water is run , then takes a while to build the pressure back up , then noise again
at least it should be an easy fix , looks like lowes stocks them
thanks guys
rmaynard
Am I to assume that we are talking about city water and not a well/pump? I have seen city water enter the house, go through the regulator, and still be near 100 psi. My son-in-law has city water, and just before the hot water heater there is a 100 psi relief valve. It constantly dripped. We decreased the pressure back to 85 and it stopped.
Depending on where you are, city water is almost always dirtier and laden with more minerals than your typical well. I would replace both the regulator and the gauge. Many times the city has to come out to shut off the water at the street since many plumbers don't put a shut off valve ahead of the regulator.
6.0 powerstroke
yes it is city water , and luckily we have a shut off inside   its in this order -
city line -   shut off   -water meter - regulator - gauge
ive tried decreasing the pressure , but didn't have any results.  I also read if you increase the pressure and run a faucet  it might clear the restriction , but then what? it goes on to block something else?
rmaynard
Once the internal parts get a coating of minerals, there isn't much that can be done to fix it short of replacing. I am not a plumber, but as a licensed home improvement contractor, I have seen my share of issues created by hard water.
6.0 powerstroke
Ok , so it not exactly a watts brand, its a Wilkins.
Biggest difference-lowes doesn't stock the Wilkins, but they did have watts
everything looks like it should line up, and as long as the fittings are right it may go right in
However, im going to wait until tomorrow incase I need to change any of the fittings
Edited by 6.0 powerstroke
6.0 powerstroke
Turns out the gauge was correct. With the new gauge I was getting 125 psi at the faucet! Old peice fought me a little coming out, but the new valve went right in. No more noise, and now a steady 65 psi
Thanks for all the replies!
rmaynard
Isn't plumbing fun? Glad you got it fixed. And you saved the price of a plumber which will allow you to buy another Wheel Horse.
6.0 powerstroke
There are a couple horses on the local cl, but I think I have to settle for a couple new tools this time
