tkeefee
520H replacement carburetor
tkeefee
I have a Onan Power Plus 20 P220G - I/10955G .
My Carb has stamped on it 6100 27-241 146-0698.
 Is the 146-0661 from ONAN a replacement for my carburetor?
Any other choices?
JackC
Here are some model numbers I put together in my search for replacement carburetors.  I prefer the non emission since they are easier to disassemble and clean.  The emissions version has an accelerator pump on the side and the service manual says to replace the emissions carburetor with a new one.
P220 non emission: 146-0414, 0496, 0375, 0479, 0381, 0430, 0386
P220 emission:  146-0660 (begin spec G), 146-0698
P216 non emission: 146-0478, 0495, 0311, 0380, 0412, 0428
P216 emission: 146-0659 (begin spec G)
146–0661 is for the Spec 11212 engine only according to the engine parts manual so it is not a replacement for the 0698 at least according to the manual.  It may actually work however.
Edited by JackC
  • Similar Content
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
    • BrianStasC-101
      By BrianStasC-101
