dclarke
RJ58 rebuild
dclarke
30 minutes ago, pullstart said:
I used it filling the hood seam after welding on Putt Putt.  It is much harder than bondo, but still sandable and workable.  It seems to have a short malleable life before hardening.
12 minutes ago, AMC RULES said:
Tip...have a cup of water on standby,  use a gloved, wetted finger to work that PC-7 into the perfect shape before it sets up.
Greatly lessens the amount of time you'll spend sanding it later.
Thanks for the info guys!
BHunter
On 1/18/2014 at 8:45 PM, dclarke said:
The hood was cracked from the weight of the gas tank so I decided to mount the tank to the frame instead of hanging it from the hood. It still needs a little tweaking but looks like it'll work. I've left a small air gap between the tank frame and the hood so it won't rub. Next I need to extend the filler neck on the tank to get it back to the correct height.
That’s nice . I really like the tank to the frame set up. You could probably sell a bunch of them.
Sarge
Once you get the repairs done - go hunt for a can of VHT vinyl dye, this stuff will permanently dye the color on the wheel across any spots you've repaired.
https://www.amazon.com/VHT-ESP942000-Vinyl-Black-Satin/dp/B000CPIN9S
Then, cover coat the entire thing in a few layers of Eastwood's Diamond Clear. This coating is UV stable and will not wear off.
https://www.eastwood.com/eastwood-diamond-clear-gloss-aerosol.html
When done, that wheel will look new, not kidding.
Sarge
dclarke
Sarge
I’ll give that a try Sarge. Thanks!
Lane Ranger
Denny:
I see Webb Sickle Service in Nebraska changed their name to Webb Cutting Components, Inc.    They still have the correct 2 inch replacement sickle bar mower blades that fit the Wheel Horse  front cutter bars (for RJ's and Suburbans) and the 42 and 50 inch Wheel Horse sickle bars.    FYI
https://www.cuttingcomponents.com/jari-replacement-section-102500-2-w-x-2-13-16-h-3-16-hole-on-1-3-8-centers.html
Edited by Lane Ranger
dclarke
1 minute ago, Lane Ranger said:
Denny:
Thanks for the info, Lane. Those blades are hard to find. I sold my sickle bar a couple of years ago.
Lane Ranger
They fit the CBR-32  front sickle bar too Denny!
Pullstart
14 minutes ago, Lane Ranger said:
Denny:
Thanks, Lane!  I have Jari and David Bradley sickle mowers, been thinking about building a front mower for my 502 out of one of them. Most likely the DB, as I’ve used the wheels and tires for my Frank build and the drive pulley is on the correct side for the :wh: PTO.
bottjernat1
I love my rj58 it took me years to get it done. Im hoping to get the mower deck restored soon. All i had for it when my late dad bought it for me when i was a teen. was a snow plow. now i have a deck i need to restore. Here is an original advertisement i have for when i show mine.
  • Excellent 3
dclarke
Very nice! I hope mine looks that good some day.
buckrancher
looking good Denny you can also get sickle bar blades from BCS the ones they use on their front mounted walk behind mower
Brian
AMC RULES
:text-yeahthat: Glen is the best!   :text-+1:
AMC RULES
:rolleyes: GO DENNY GO!!! :woohoo:
  • Haha 1
Pullstart
Yep.
  • Haha 1
dclarke
Craig, I started on this 5 years ago. I need to get going on it. 😂
  • Haha 3
AMC RULES
Your restorations are always top notch Denny, the final results will be well worth the wait.  :popcorn:
Sarge
Just fyi - there are some very thin bronze washers/bearings available from McMaster for additional wear point protection. You could also just use brass shims if there isn't enough room.
Sarge
dclarke
Sarge
Thanks Sarge, I’ll check that out.
WHX??
Been there done that Denny...You prolly been busy with 520's and LR's!  good things come to those that wait!
Chiming in to hopefully follow to the finish!
BTW that will steer nice with those bushings, I did similar on a few builds and steer better than new! :handgestures-thumbupright: Well worth the effort.
dclarke
Jim, I've got two builds going this winter and it's stretching my :wh: budget more than I thought it would. I'm hoping to have them both done in time for the show in Portage. We'll see.
Shynon
:woohoo:
AMC RULES
I's the little things that make all the difference Denny...wheel looks really great!  :handgestures-thumbupright:
  • Similar Content
    • CasualObserver
      By CasualObserver
      Operator manual
      Illustrated parts list
      6 pages 3.73MB
      Illustrated parts list #A-7136
      Includes PSB #023 #052 #058 #060 #080
      10 pages 938.48KB
      Engines used according to Toro
      Clinton B1290-1107
      Kohler K91-31307A
      Kohler K91-31388A
      Electric start kit
      Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
      Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
      6-12 tire chains model TC-12 - Listed for 1958 and 1959
      Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
      Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
      Details & Attachments
      2 pages 107.33KB
      1958 model RJ-58
      1958 serial numbers that have shown up for the RJ-58
      Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      00005
      00251
      01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
      01188 - Has round rear wheel hubs
      01516
      01636
      01768
      01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
      01797
      01871
      02525
      03177
      03501 - Located in UK
      03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      04041
      04883
      04885
      05000
      05619
      05714
      05798
      06528 - May be 16528
      06749
      06771
      07633
      07649 - Transmission J12-8 October 12, 1958
      07725
      08440
      08612
      09284
      09337 - Hard to read
      10163
      11432
      11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
      11916
      12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
      12291
      14473
      14713
      16097
      16528 - May be 06528
      166x6
      16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
      18348
      June 2023
      18500 and lower
      Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      2 pages 106.94KB
      1959 model RJ-59
      1959 serial numbers that have shown up for the RJ-59
      Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      18501 and up - Possible 1100 units built
      20078 - Located in UK
      203xx
      21033
      21259 - F30-9 trans casting date = June 30, 1959
      292xx
      21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
      Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
      K91T-31388A Serial 425251 found on RJ-59
    • bigbuck
      By bigbuck
      I'm not positive of the model, but I think I'm close. Please call George at 517-499-5678
    • RJcollector
      By RJcollector
      Ive been thinking about selling my 4 RJ-58s and all the attachments and parts I have. I have 4 tractors-2 have Kohler K91T , 1 has the Clinton and one has no engine. Only 1 is missing the serial number decal. Kohlers run. Clinton needs a carb. I have original exhaust shields AND belt guards for 3 of them. 3 mower decks, 2 plows, cart, 2 spare transmissions, parts breakdowns, original manuals and sale tags, seats, tires.  Not sure if I should sell it as 1 big collection or break it up. And also a good starting price?  I'll post pics when I get a chance. Thanks
    • wh315-8
      By wh315-8
      The RJ58 was the big hit for spectators this year at my local festivals here in Carroll County OH.
      the children loved getting their pictures sitting on it, then they discovered the bicycle horn under the steering wheel. It’s always a joy even in parades. Just love showing off part of my collection every year and hearing all the stories from those that had WH in their lives at one time. Can hardly wait to get to retirement so I can get some of my other models back to their glory in working order and be able to attend other shows/festivals throughout the year. My fellow tractor enthusiasts always know when a spectacular starts asking about WH, they point in my direction. I study up on the history of the different models and always intrigue those that didn’t know much about how WH came to be. This website is one place that has helped me learn so much about the WH history and I thank you for sharing your knowledge that I am able to pass on to keep WH alive and well.
