WHEEL HORSE BILL
No spark c-101
WHEEL HORSE BILL
Ok guys I bought a c-101 with no spark I changed to coil no spark changed to points no spark.What could be wrong motor turns over but still no spark.Any idea on what it could be :eusa-think:
rmaynard
The 12 volts to the coil goes through the PTO safety switch and the seat switch. Are the safety switches working correctly?
WHEEL HORSE BILL
The guy who owned it by passed the safety pto and the seat but i think that might be the problem.Nice tractor all I want it for is to plow and use it for the garden.what is the right way to by pass all that.
rmaynard
There is no right way to bypass the safety switches since they are there for your safety, but as a temporary solution to your problem, a wire directly from the (I) terminal of the ignition switch to the (+) lug of the coil will bypass both.
WHEEL HORSE BILL
Just to test can i run a wire from (I) to  the + lug while everythnig is connect or do i have to disconect anything.
WHEEL HORSE BILL
I want to put a 16 horse kohler in there but I want to know if this engine runs good to save for a later date.
rmaynard
A direct wire should work without disconnecting anything else.
WHEEL HORSE BILL
Nope it didn't work.I'll just have to rewire the whole thing it is a mess.
rmaynard
Assuming that you have a good clean set of points set to a gap of .020", a good spark plug, spark plug wire, and the correct coil, you should have spark if you have +12v at the (+) side of the coil, and the (-) side of coil connected to the condenser and points.
Temporarily connect a wire directly from the positive side of the battery to the coil and see what happens. Don't leave it connected when not running or you could burn out the new coil.
Lagersolut
I'll throw in my .02 - I was out pushing snow with my C-101 and it started to knock and rattle ( just rebuilt this year ) spit sputter etc .... shut it down , checked the oil , carb  etc etc ....nothing wrong ...wouldn't start - turned over   ...nothing   ...... scratching my head  ........long story short the wire broke off " inside " the fuse holder coming off the solenoid .....check your fuse and wire ....
Edited by Golds-Red
C-101plowerpower
dead condensor?
GT14
Something simple to check. Is the condenser connected to the negative side of the coil? When dealing with an inherited problem these things can bite you.
  • Similar Content
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Seat, New! Universal Garden Tractor / Riding Mower Seat
      This is a new seat that I purchased for a project tractor and never used, it is in Perfect as New Condition.
      I have used this seat on a few Wheel Horse tractors, and they have been a perfect fit and look great.
      This is a Universal fitment seat; it has multiple mounting holes and mounting patterns for fitment on most Graden Tractors and Riding Mowers.
      $49.00  Call Tim @ 1-313-460-8858     (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
      These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
      Great for any Garden Tractor or Riding Mower
      They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
      $99.00 Call Tim @ 1-313-460-8858        (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      C - Series, Hood and Sheet Metal (square black insert) (also known as black hood models) for sale!
      This sheet metal set, including C Series Hood, Dash piece, Seat Bracket, and Left & Right-Side Covers, and Left & Right Floorboards was sandblasted, epoxy primed, and painted the OEM Wheel Horse Red Paint.
      The painted set is not perfect, a little metal pitting on one of the floorboards, a few little imperfections in the paint here and there as I'm a rookie painter, but this is a nice painted set of sheet metal to freshen up your C Series Wheel Horse!
      $140.00 O.B.O. Call Tim @ 1-313-460-8858        (No Shipping, Local Pick-Up Only)
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
