tmix 34 #1 Posted December 22, 2013 I need a better way to lift the plow. See i have a 5' blade on a 12hp Raider it's a pull to get her off the ground after 40 or 50 times. Maybe just getting old non the less need a new trick. I do have a old western plow electric over hydraulic thought maybe mounting on the front and using it for up & down. Has any body tried this? Also have heard talk about something called a linear actuator. If any body can shine some light on the matter would be GREAT!!! Share this post Link to post Share on other sites
timo4352 148 #2 Posted December 22, 2013 No need to reinvent the wheel here, unless you want to... The Wheel Horse lift does just fine. Share this post Link to post Share on other sites
tmix 34 #3 Posted December 22, 2013 No need to reinvent the wheel here, unless you want to... The Wheel Horse lift does just fine. WOW how do i got about getting one and what did they come from? Thats cool were do i get one? What tractors had them Share this post Link to post Share on other sites
timo4352 148 #4 Posted December 22, 2013 I would probably check with Kelly first to see if he has one. Others on here may have one from a parts tractor or something... I do have the manual from mine- and the part number is 8-4225 Toro electric lift kit. Partstree.com shows it discontinued. I should probably upload this manual to the site for everyone - - I'd have to figure out how to do that first though... Now- besides all this --- do you have the helper lift spring on your tractor? That may be all you need. Share this post Link to post Share on other sites
rwilson 128 #5 Posted December 22, 2013 Lift assist spring??!! Share this post Link to post Share on other sites
tmix 34 #6 Posted December 23, 2013 would someone have a pic of this lift assist spring? WOW my arm is tired Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #7 Posted December 23, 2013 The lift assist spring is used with the snowthrower and attaches between a tab on the "flag" and the footrest mounting bar. I'm sure you could add a custom assist spring somewhere, but it can't be too strong or it won't allow the blade to ride firmly on the ground. The electric lift pictured above is for the newer models and won't work on pre-'78 tractors. There was a discussion on the forum a few years ago about adding the lift cylinder and control valve from a same-generation hydro tractor and powering it with an automotive power steering pump driven off the PTO. Another option would be to use an electric over hydraulic pump like those used on motorhome leveling jacks or convertible tops. Share this post Link to post Share on other sites
shorts 182 #8 Posted December 23, 2013 (edited) Vendor Glen Petit sells the lift springs for tillers and snowblowers, check his site Edited December 23, 2013 by shorts 1 Share this post Link to post Share on other sites
jimt1971 237 #9 Posted December 23, 2013 Electric winch hung off the front attachmatic works great. Share this post Link to post Share on other sites
dodgemike 52 #10 Posted December 23, 2013 I have pictures posted in the Dozers and blower section. I did This about 5 years ago. Small ATV Winch and simple bracket. Made It a lot more fun to plow snow! Sent from my SCH-S720C using Tapatalk 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,092 #11 Posted December 23, 2013 I should probably upload this manual to the site for everyone - - I'd have to figure out how to do that first though... We have this manual for the 8-4225 Thanks for the offer. Garry Share this post Link to post Share on other sites
tmix 34 #12 Posted December 24, 2013 No need to reinvent the wheel here, unless you want to... The Wheel Horse lift does just fine. Guess if i found one it wouldn't work anyway =( Share this post Link to post Share on other sites
tmix 34 #13 Posted December 24, 2013 Thanks for the HELP guys. Winch it well be Share this post Link to post Share on other sites
timo4352 148 #14 Posted December 25, 2013 I met a guy this summer at the lake who used an ATV winch to raise and lower the mast on his sailboat single handed. It worked very well for his use. I think he said he got it from Harbor Freight or Northern Tool. His had a remote wire control. Could be made to work your plow lift. Share this post Link to post Share on other sites
AMC RULES 37,255 #16 Posted December 27, 2013 Lift assist spring??!! 1 Share this post Link to post Share on other sites
Kelly 1,038 #17 Posted December 27, 2013 Craig, that is for the blower, the spring will work on a tiller, but they never made one for a plow, as was said above it would have to be a light duty spring almost not worth having Share this post Link to post Share on other sites
timo4352 148 #18 Posted December 27, 2013 You might also look at a linear actuator to do the job. https://www.google.com/shopping/product/4913557210980926987?q=linear+actuator&espv=210&es_sm=93&bav=on.2,or.r_qf.&bvm=bv.58187178,d.b2I,pv.xjs.s.en_US.EeLgqkzqnSg.O&biw=1920&bih=979&tch=1&ech=1&psi=34a9UtXlAoXd2QX_y4CACA.1388152542210.3&ei=DYe9UquBMMie2wX9n4GYAw&ved=0COEBEKYrMAY Share this post Link to post Share on other sites
over60pirate 24 #19 Posted December 30, 2013 The winch and mount I made, can be used with a rear axle mounted plow also. I made this plow mount, because I didn't want to remove the mower deck, just to use the plow. I also made a plywood bucket bottom, for this plow. 2 pins pulled and the winch can be mounted in the rear, for implement lift. Pull 1 pin, and the mount tilts forward to allow the hood to be opened. After the picture was taken, I added power disconnect plugs to the front and rear of the tractor. 4 Share this post Link to post Share on other sites
posifour11 723 #20 Posted January 2, 2014 That's pretty darn neat! I like that! The winch and mount I made, can be used with a rear axle mounted plow also. I made this plow mount, because I didn't want to remove the mower deck, just to use the plow. I also made a plywood bucket bottom, for this plow. 2 pins pulled and the winch can be mounted in the rear, for implement lift. Pull 1 pin, and the mount tilts forward to allow the hood to be opened. After the picture was taken, I added power disconnect plugs to the front and rear of the tractor. 1 Share this post Link to post Share on other sites
davedean 2 #21 Posted January 6, 2016 where do I go to find Glen Petit's site? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,092 #22 Posted January 6, 2016 Go down to the Classifieds and then you will see Glen as the first Vendor http://www.wheelhorseforum.com/ Garry Share this post Link to post Share on other sites
