snowhound 106 #1 Posted December 21, 2013 A co-worker and I were talking about how bad todays gas is and when I asked him what additive he used he said "ATF about 2 oz. per gallon" He clames it works better than Sta-Bil or any other stabilizer. Has anyone else heard of this or tried it? Ed Share this post Link to post Share on other sites
953 nut 63,782 #2 Posted December 21, 2013 (edited) I do recall people using ATF as a "Top Oil" to clead up the carbon in the valve train years back, never did so myself. If you are talking about long term storage I would suggest you remove all of the gas from your tank, get some ethanol free gas in the tank and run it long enough to be sure the carb. has no more E-10 in it. If you want to use an additive SeaFoam is the best. You can find out where to get ethanol free gas at buyrealgas.com, put in your Zip code and it will give you a list of stations in your area. Edited December 21, 2013 by 953 nut 1 Share this post Link to post Share on other sites
speedyleedy 205 #3 Posted December 21, 2013 I 've had the best luck with seafoam myself.... 1 Share this post Link to post Share on other sites
cheesegrader 434 #4 Posted December 21, 2013 Another vote for seafoam. 1 Share this post Link to post Share on other sites
flyovrcntry 115 #5 Posted December 21, 2013 If your tank is metal a full tank will prevent moisture,therefore rust. I was under the impression premium gas was ethanol free,is this not true ? Share this post Link to post Share on other sites
timo4352 148 #6 Posted December 21, 2013 Ever since I shelled out around 400 bucks for a real chain saw, I've been using Startron. Using it in all my small engines now, including the tractor. It's the only one I've heard of that eliminates ethanol problems. So far so good. 1 Share this post Link to post Share on other sites
fireman 1,022 #7 Posted December 21, 2013 I second the Startron. Use it in everything. You also want to use a lead additive if your engine is older then like 1975. They need the lead for the lubricative properties. Share this post Link to post Share on other sites
Ed Kennell 44,365 #8 Posted December 21, 2013 I use Marine grade Sta-Bil (the tan color, not red) In all my Mercury outboards,2 and 4 strokes, Brigs mowers, Kohler and Techy tractors, Honda pressure washer and log splitter, Poulon trimmers, Onan generator, and Yamaha 4 wheeler. I have only plastic fuel tanks, so I drain or siphon all gas out. then disconnect the fuel line from the tank and put it in a soup can filled with 5oz of pure gas and 1oz of Sta-Bil. For the 2 strokes, I also add 1oz of oil. Then start the engine and just before it runs out of fuel, spray ~ 3-4 seconds of fogging oil into each carb. I then pull the spark plugs and spray fogging oil into each cyl. for 3-4 seconds. I have never had any problems using this treatment for long term storage. For short term storage ,less than 1 month, I just add the Sta-Bil as recommended by the Manufacturer. Share this post Link to post Share on other sites
Jrblanke 918 #9 Posted December 21, 2013 If your tank is metal a full tank will prevent moisture,therefore rust. I was under the impression premium gas was ethanol free,is this not true ? I believe it differs from state to state. In my state, 99% of gasoline contains some percentage of ethanol. There are very fiew stations that sell true ethanol free gas. There is a BP station here in Raleigh that advertises that it carries 89 octane, ethanol free gas. It is more expensive than premium but less expensive than diesel. Out of the 16 pumps at the station, only 1 pump has the ethanol free gas. For those of you in Raleigh, it is the BP station at the intersection of Duraleigh Rd and Glenwood Ave (next to chick fil a...yum). 1 Share this post Link to post Share on other sites
MooneyM20F 4 #10 Posted December 21, 2013 100LL aviation fuel. Has a very low lead count, does not sour in the tank. Smells good. Works great in air cooled engines, I also use Aeroshell aviation oil. I have seen what happens to air cooled aviation engines after running on oil intended for liquid cooled engines. You can pick the 100LL fuel up at most airports. Share this post Link to post Share on other sites
Anglo Traction 761 #11 Posted December 21, 2013 100LL aviation fuel. Has a very low lead count, does not sour in the tank. Smells good. Works great in air cooled engines, I also use Aeroshell aviation oil. I have seen what happens to air cooled aviation engines after running on oil intended for liquid cooled engines. You can pick the 100LL fuel up at most airports. When you say low Lead count, do you know that there is over 1.2 grams of Tetraethyl Lead in each U.S Gallon of Avgas 100LL?. Share this post Link to post Share on other sites
Forest Road 595 #12 Posted December 21, 2013 All gas in NY and NJ has ethanol. Unless its marked E- free. Cant speak for the rest of the country .I purchase E-free at a marina in the summer and a snowmobile dealer in the winter. I probably use 20-30 gallons a year. So i dint mind the extra $1 per gallon too much. As for additives I've been happy with Star-tron. It's been used in marine applications for many years. I'm not a fan of Stabil because there have too many discussions that in my opinion has lead to confusion and aome arguments over which Stabil to use. Yamaha also makes a product available through dealers. I've heard nothing but praise for it. Share this post Link to post Share on other sites
MooneyM20F 4 #13 Posted December 21, 2013 Yeah.....1.2... Depends where you get the info........ As I was saying, works great, smells great, won't sour Share this post Link to post Share on other sites
Digger 66 3,523 #14 Posted December 21, 2013 (edited) You can find out where to get ethanol free gas at buyrealgas.com, put in your Zip code and it will give you a list of stations in your area. Another vote for Seafoam & here's a clickable link for getting non-oxygenated fuel > http://pure-gas.org/ Edited December 21, 2013 by Digger 66 Share this post Link to post Share on other sites
Anglo Traction 761 #15 Posted December 21, 2013 Not sure if you have a similar fuel in U.S , but there is an Alkylate Fuel available in Europe called Aspen. It is prohibitively expensive at the moment because of it's production method and low usage. Despite the cost, it is good for 5 years in the tank/Carb and fuel lines. Perfect for Low Use equipment and Show Queens and has very low emissions . There are several additives available here and of course we are only at the 5% Ethanol level at the moment. I use Redex in the Fuel, purely as an 'Upper Cylinder Lubricant' and it also cleans out or prevents the carbon build up. Had the Can for 20years now, still plenty left. 1 Share this post Link to post Share on other sites
Buckshot 1 15 #16 Posted December 21, 2013 I use Seafoam and MMO. . 1 Share this post Link to post Share on other sites
dbartlett1958 99 #17 Posted December 22, 2013 Seafoam and TWC-3 two cycle oil at 2 ounces to 5 gallons of gas. I use my tractor a lot, so I don't worry about the ethanol free. Share this post Link to post Share on other sites
rmaynard 16,820 #18 Posted December 22, 2013 I don't use any additives in my gas. Have tried Seafoam, and Stabil. Neither have shown me any benefits when running, or when the gas is left in the carburetor over the winter. My current weatherization includes using ONLY ethanol-free gas during the spring, summer, and fall, then running the tanks dry before putting the tractors away for the winter. Fortunately for me, I have found a station that sells only e-free gasoline. They are 48 miles round-trip from my house, so I take 5 five gallon cans with me and fill them up each time I go. After a summer of ethanol related repairs to my leaf blowers, chain saw, and generator, I decided that I will only use ethanol free gas from here on out. That is, as long as it is available, and the EPA doesn't shut down the suppliers. Share this post Link to post Share on other sites
rick 258 #19 Posted December 22, 2013 Gotta love that Blue Devil! I add MMO to my 100LL AvGas. Share this post Link to post Share on other sites
MooneyM20F 4 #20 Posted December 23, 2013 I add a little Marvel too. Works great. I buy the MMO oil by the gallons. I run it in the oil an fuel of the plane I fly for a living, I suffered from stuck valves a few years ago. With the MMO, I have had over 1100hrs of trouble free operation. I have had many hrs of trouble free operation in my tractors as well. Ethanol is trash, if you have the ability to get a better fuel, do it. 1 Share this post Link to post Share on other sites
snowhound 106 #21 Posted December 23, 2013 I do us Seafoam and Marvel but I hadn't heard of using ATV and was wondering if it was somewhat common knowledge that it could be used. Thanks for all the replys A Merry Christmas and Happy New Year to all Ed Share this post Link to post Share on other sites
userj8670 68 #22 Posted December 24, 2013 Does anyone use any lead additive? Share this post Link to post Share on other sites
userj8670 68 #23 Posted December 24, 2013 I recently started using sea form but have yet to see any benefit Share this post Link to post Share on other sites
Digger 66 3,523 #24 Posted December 24, 2013 Does anyone use any lead additive? I do in the snowblower , its a 1966 model & requires it for valve-seat longevity . Share this post Link to post Share on other sites
userj8670 68 #25 Posted December 25, 2013 I have heard yes and no Share this post Link to post Share on other sites
