scrappie24 1 #1 Posted December 19, 2013 (edited) New To All Of This Hope I Posted In The Right Place. Have A 520H With An Onan P220G-I That Runs Intermittently Sometimes There Is Spark And It Will Run For About 20-30 Minutes Then Just Shuts Down And Wont Refire. Have Already Replaced The Coil Then It Fired Right Up Ran A Bit Then Same Problem.. Not Sure If A Relay Is Bad Or What..Please Help Thanks Edited December 19, 2013 by scrappie24 Share this post Link to post Share on other sites
JackC 619 #2 Posted December 19, 2013 Sounds like it could be an intermittent wiring issue. The fuse holder sockets have been a large source of connection issues. You might try to clean them or temporarily bypass them and see if there is any change. Share this post Link to post Share on other sites
scrappie24 1 #3 Posted December 19, 2013 Do The Fuses Have Any Control Over Spark? Share this post Link to post Share on other sites
JackC 619 #4 Posted December 19, 2013 Here are the 520 wiring diagrams: Share this post Link to post Share on other sites
Red-Bovine 337 #5 Posted December 19, 2013 I had a similar problem with the Onan on my 520H. It turned out to be the trigger and magnet under the flywheel. Mine would run for a while and would stop dead. Would restart after a few minutes, then die off again. Red Share this post Link to post Share on other sites
scrappie24 1 #6 Posted December 19, 2013 Forgot To Mention One Thing After The Engine Dies, I Pulled The Plug Wires Put Spark Plugs In And Check For Spark Nothing Until You Turn The Ignition Off Then It Will Give A Good Spark. Share this post Link to post Share on other sites
Red-Bovine 337 #7 Posted December 19, 2013 There should be some OHM value for the trigger. You can disconnect the wires going to it from the coil and check that. Not sure what the value is, but somebody here will know. Red Share this post Link to post Share on other sites
scrappie24 1 #8 Posted December 19, 2013 Thanks Red And JackC. We Will Be Working On It Today Will Let You Know What We Find. Share this post Link to post Share on other sites
knkinsulation 0 #9 Posted January 27, 2014 I am having the same problem HELP PLEASE Share this post Link to post Share on other sites
JackC 619 #10 Posted January 28, 2014 Here is a test procedure for the electronic ignition module to go with the wiring diagrams in an earlier post. 1 Share this post Link to post Share on other sites
Touti 0 #11 Posted March 9, 2014 Hello scrappie 24 , I am an owner of a 416-H and i have the same problem of you and like you i change the coil and still got the problem Did you find something that can help me to resolve the problem Thank you Share this post Link to post Share on other sites
scrappie24 1 #12 Posted March 9, 2014 Our Problem was A Bad Trigger Under The Flywheel Thanks To All Share this post Link to post Share on other sites
