bigboy63 1 #1 Posted December 14, 2013 Bought a snow blower that was on a c series no model # mounted on my 416-h but belt that is on blower seems short ? am I missing something on the install or do I need a different size belt an if so how can I figure out what one seeing the blower has no #s ? thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #2 Posted December 14, 2013 A 5/8" x 69" belt should work on both series of tractors. Belt travels off the outer groove of the pto, under the V-idler, over the flat idler and around the snowthrower pulley and back to the top of the pto outer groove. Garry 1 Share this post Link to post Share on other sites
dbartlett1958 99 #3 Posted December 16, 2013 Like Garry said, same belt works with both blowers. Unless somebody modified something, it sounds like the belt is routed incorrectly. This is easy to do. Find some pictures or down load the manual. Share this post Link to post Share on other sites
bigboy63 1 #4 Posted December 28, 2013 The pulley on the blower must have been changed had to use a 5/8x72" belt and was hard to get on and that was to the smaller pto pulley . works fine now. thanks again Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #5 Posted December 28, 2013 In most cases, it's impossible for the blower to have a larger than stock input pulley because of the wrapper location. This is a 06-42ST04 (1986) thrower on a 1992 416-8: That's an OEM #9750 belt and I've used that thrower with that same belt on several different tractors. Maybe you have a thrower with a modified hitch? Here's a measurement pic: Can you post pictures of your thrower? Share this post Link to post Share on other sites
dbartlett1958 99 #6 Posted December 28, 2013 Ditto to what TT said! On my blower, you need to partially disassemble it to change the belt. The pulleys normally run close to the blower housing. I am confident that the pulley is correct, and that your belt length issue is the result of something else that is different. Share this post Link to post Share on other sites
