Machria 78 #1 Posted December 10, 2013 (edited) My GT14 has regular garden tires on it, with chains installed. Works fine in woods (hauling firewood out), and works fine in the snow snowblowing. BUT, it's bunpy and lumpy and makes noise when I'm on the street with the chains. I often have to go a 100 yards or so down the payvment to get to the woods.... and I'm sure that doesn't do the chains any good. So, would I be better off with an Agro type tire? Do agro's work ok in the snow, as good as chains? OR? Edited December 10, 2013 by Machria 2 Share this post Link to post Share on other sites
Brrly1 1,146 #2 Posted December 10, 2013 With the GT14, I use the inside wheel weights with chains but I have different setups. On the xi I have wheel weights with the Firestone ags, tri-ribs on the front with no problems. Quick question, are you running 12" rims on your tractor? Should be 15". Good luck Let us know how you do Share this post Link to post Share on other sites
Machria 78 #3 Posted December 10, 2013 Got me, where would I measure? Are you referring to the width of the tire, or the diameter of the rim? Does this pic help? 2 Share this post Link to post Share on other sites
dbartlett1958 99 #5 Posted December 11, 2013 If you think your ride is bumpy now, Try some AG's on there, and then you'll know what bumpy is! Your set-up with chains should give you all the traction you need, and give you the best ride. You should get some wheel weights though. More weight will help a lot with traction. Share this post Link to post Share on other sites
.5racer 15 #6 Posted December 11, 2013 slap some bungy straps on the outside them chains in a V fashion and that will take up some slack . As far as wear, I wouldn't worry too much unless you spin on concrete a lot. Share this post Link to post Share on other sites
rmaynard 17,113 #7 Posted December 11, 2013 If you think your ride is bumpy now, Try some AG's on there... And if you really want a bumpy ride, put some chains on the AG's. 1 Share this post Link to post Share on other sites
Ken B 3,203 #8 Posted December 11, 2013 The Ags won't give near as good traction on snow and ice as chains will.... 1 Share this post Link to post Share on other sites
Coadster32 793 #9 Posted December 11, 2013 Chains are superior, but Ag's hold their own pretty well. Deflating your tires, then tightening up the chains really good, helps with the slack as well. (don't forget to re-inflate) 2 Share this post Link to post Share on other sites
Brrly1 1,146 #10 Posted December 11, 2013 Looks like 15" rims. The GT14 are like the same lug pattern as the 953,1054 the four bolt lug. They came out with wheel weights (two piece) that bolt on to the inside of the wheel but mount to the axle. You then put lug nuts on the outside of the tire, of course to hold in place. Find some of the weights for the rear and away you go. You might even go as far as front weights. Good Luck Share this post Link to post Share on other sites
leeave96 496 #11 Posted December 11, 2013 IMHO - chains rule, but I've had GREAT luck with ag tires and typically run them year round. 1 Share this post Link to post Share on other sites
i967mustang 21 #12 Posted December 12, 2013 I had a charger 12 awhile ago that had Ags on it, I had them filled with anti freeze and water mix. The Charger 12 I have now has chains, I much preferred the ride of the Ags to chains. Haven't plowed with the chains on this Charger but did a lot with the old one, it Plowed great. Nothing would stop that little tractor. Share this post Link to post Share on other sites
pfrederi 20,328 #13 Posted December 12, 2013 If you have frozen ground/ice under your snow AGs will be a huge disappointment ...Chains rule on ice/frozen ground. (Also if you ever have to back up hill with AGs you are lost) I have a Farmall M with Ags, 750 lbs of beet juice on each side and 150 lbs weight on each side she won't backup hill if it is icy.. Share this post Link to post Share on other sites
AMC RULES 37,256 #14 Posted December 13, 2013 I'm really digging that winch mount Machria. Share this post Link to post Share on other sites
Brrly1 1,146 #15 Posted December 13, 2013 The 15" ags for GT14 are hard to find unless you want to run skid steer tires(NOT)because they no longer make them. Wait I stand corrected they do make a 7.60 thats made by American Farmer carried by Miller Tire in Ohio. Thats about an 1" or so differance. Nobody makes the 8.50 anymore Share this post Link to post Share on other sites
Machria 78 #16 Posted December 14, 2013 I'm really digging that winch mount Machria. Scot on this site built that for me. I just had him customize the "custom 2" hitch" he makes. Here was the tread, check out post #78: Here is the latest build, you can order one.... . 1 Share this post Link to post Share on other sites
AMC RULES 37,256 #17 Posted December 14, 2013 Nice...did your roller fairlead come from Northern tool as well? Share this post Link to post Share on other sites
Machria 78 #18 Posted December 15, 2013 Yes, comes as part of the winch. Think I bought it on sale on Amazon for $75 Share this post Link to post Share on other sites
oaktown1987 82 #19 Posted December 15, 2013 i got ag tires on my 875 and its pretty bumpy but never used chains Share this post Link to post Share on other sites
Brrly1 1,146 #20 Posted December 17, 2013 Quick remedy, keep your chains and add some of the 953/1054/GT14 rear weights. One other thing tighten up you chains. Let some of the air out tighten or snug them up and reinflate. Sure it will be bumpy it's basically part of life in the snow. Don't think I have ever had a smooth ride whether I am using ags or chains Share this post Link to post Share on other sites
KC9KAS 4,746 #21 Posted December 17, 2013 (edited) I have been using turf tire with fluid and 4 link chains for several winters and have been very happy with the results. I keep them as tight as I can so then don't sling into a fender. This year, I installed a pair of 2 link chains and was amazed at how smooth the ride is. You have the right size tires on your GT-14 and the 2 link chains, so as others have stated add some weight, tighten the chains and you will have the best all around traction set-up (my opinion). You can't see the inside weights, but they are there. Edited December 17, 2013 by KC9KAS 1 Share this post Link to post Share on other sites
Machria 78 #22 Posted December 17, 2013 Ok, thanks guys. Seems like the consensus is tighten up the chains (which I had never thought of) and leave the turf tires and chains on, and add weight if possible. I've been trying to get some wheel weights for this thing, but have not been able to find them. The only pair I saw available last year were priced higher than what I paid for the whole tractor. I need to find something more reasonable. So off to figure out how you tighten up chains.... Share this post Link to post Share on other sites
Kelly 1,038 #23 Posted December 17, 2013 to tighten the chains, jack up one side of the tractor with tire off the ground, let the air mostly out of the tire (you do have a way to blow them back up right??) this works best if the tire is warm, but works cold also, release the latch but don't unhook the chain, square the chains up on the tire and hook the side with out the latch as tight as you can, then rehook the latch side as tight as you can and relatch, blow the tire back up to proper PSI, if the chains are still loose you may try again, key is to aline the chains all the way around the tire as you are trying to get them tight, but if all else fails hook a bungee cord from one part of the chain across the face of the rim to the other part of the chain wrap the bungee around the chain and back to the other side of the rim so the bungee looks like a V on the face of the rim, some time you need to use 2 bungees at 90 deg to form a star pattern this will help with the slack in the chains. On a side note I run my latches on the out board side of the tire, and I use a zip tie to secure the latch and any loose ends on the chains. Share this post Link to post Share on other sites
1989520HC 13 #24 Posted December 21, 2013 If you have frozen ground/ice under your snow AGs will be a huge disappointment ...Chains rule on ice/frozen ground. (Also if you ever have to back up hill with AGs you are lost) I have a Farmall M with Ags, 750 lbs of beet juice on each side and 150 lbs weight on each side she won't backup hill if it is icy.. Ok I have to ask....what is beat juice doing in your tires? Share this post Link to post Share on other sites
rexman72 210 #25 Posted December 22, 2013 chains rock just ask the skidder operators who use them. Share this post Link to post Share on other sites
