AMC RULES 36,961 #1 Posted December 8, 2013 Saw this article on line... http://www.enginerepairshop.com/automotive-machine-shops.html got me to thinking...I wonder if our members could share any tips/experience that would help one to choose the best machine shop locally for rebuilding a tractor's small engine? 1 Share this post Link to post Share on other sites
Wishin4a416 2,189 #2 Posted December 8, 2013 (edited) Great idea Craig! Sort of like the dealer list we have. I know I might need one shortly and my hometown shops have dryed up. The pullers in my area all use a fellow in Oh about 4 hrs away. Oops I guess I read it wrong the first time. I was thinking a Shop list My problem is my small engine shops have dissappeared. The people have retired and the throw away machines have put some out of business. Even the good Auto machine shops have moved. Edited December 9, 2013 by Wishin4a416 1 Share this post Link to post Share on other sites
shorts 182 #3 Posted December 9, 2013 Ask around, word of mouth is probably the best way to find a machine shop, check out the independent auto parts suppliers and repair shops, if they can't do the work for you they probably know who can or will machine a small engine. Check in heavy truck, farm and equipment shops they still have a need to repair/rebuild components instead of replacing them. Modern equipment and manufacturing process have turned us into a throw away world, often times it's most cost effective to replace parts with new than it is to machine and refurbish with the cost of skilled labor and high tech equipment. 1 Share this post Link to post Share on other sites
Wheel-N-It 2,967 #4 Posted December 11, 2013 No real tips here Craig, but for anyone interested in a rebuild in my area just PM me and I'll give you my best recommendation. 1 Share this post Link to post Share on other sites
AMC RULES 36,961 #5 Posted December 11, 2013 Thank you Van. Share this post Link to post Share on other sites
buckrancher 2,678 #6 Posted December 11, 2013 I get all my motors done at Bennett Die & Tool Share this post Link to post Share on other sites
baerpath 517 #7 Posted December 11, 2013 We have three circle tracks and two strip tracks close by, plus the pullers so we have a 5 shops in the area and 2 I would say are real good. Also have 3 dyno's for small engines in the area. I use mainly Danibles Machine Shop Share this post Link to post Share on other sites
richmondred01 2,209 #8 Posted December 12, 2013 I've been rebuilding kohlers for over 35 years. Only do the k series now. If required it's bored, crank ground, valve seats ground, valves replaced or resurfaced, valve guides replaced if needed. New piston, rod, rings, seals and rebuild carb. Located in Richmond Virginia. I have little to no over head and my rebuild prices are 60-75 % less then dealers or machine shops in the area. PM me for details. I don't do pulling engines. Mine go back to spec. 3 Share this post Link to post Share on other sites
AMC RULES 36,961 #9 Posted December 13, 2013 Now that's a good tip. Share this post Link to post Share on other sites
