HorseFixer 2,012 #1 Posted December 2, 2013 Over the weekend I was cleaning inside and around the Auger in the Snow Chucker while doing that I grabbed the Auger gave it a yank (Checking the Bearings) and sure enough I had some slop and end play. I took both sides apart and the outer auger shaft rides on a Bronze Bushing. The pillow block itself seemed okay but the Bushing was wore out. The bushing looked familiar so I looked over in my parts supply and found a couple Of new axel bushings that are replacements for the front Rims in this case of an RJ. They were a 1/16th of an inch long so I ground them down. I heated up the pillow block it has a wicking inside it and I soaked it in OIL so it would draw in the oil in the wicking so to lubricate the bronze bushing. I installed a 1" washer on each side and that took the side play out of the auger. I intended on rebuilding the blower earlier this year but didn't get around to it my question is has anyone replaced these cheap pillow blocks with a grease able flange bearing? It sure seems like a better bearing should be used to support each end of the Auger. Also how much side play is in your tall chute blower? Thanks ~Duke Share this post Link to post Share on other sites
wallfish 16,038 #2 Posted December 2, 2013 Are you talking about a 2 stage blower? If so, I was thinking the same thing as I just replaced those little balls with bushings in them, which cost $18 each from PartsTree. I could have picked up some real ball bearing 4 hole flange mounted type for the price of one of those bushing type. 1 Share this post Link to post Share on other sites
HorseFixer 2,012 #3 Posted December 3, 2013 Yes, John, those are the Ones on each side of the auger. Did you soak the pillow block balls with wicking in them in oil? The bronze bushings are OILLITE I think they are called that. Any way those need replacing for sure with REAL BEARINGS While I was inside the Auger looking around I see lots of rough edges and areas there should be continuous welded to prevent ice and snow from getting in the cracks and sticking to them. My thinking anything you can do to make the blower spin freely and efficiently along with less friction inside the auger and chute is what I plan on doing. ~Duke Share this post Link to post Share on other sites
MalMac 1,328 #4 Posted December 3, 2013 Duke for some reason I remember a post on here where someone replaced those bushing with something better. Maybe it was a single stage someone redone. I have sleep since then. My brain housing group now-a-days only has the capability of retaining info for approximately 12hrs then it's gone. At least that what the wife tells me. Share this post Link to post Share on other sites
wallfish 16,038 #5 Posted December 3, 2013 They came oiled up or at least appeared to be. I'm not to concerned about them since they will be replaced to a real bearing when they wear out again. I cleaned the shafts up and smoothed them out the best I could but still had some rust pitting to grind those bushings quicker. Here's what I should have used in the first place http://www.surpluscenter.com/Power-Transmission/Bearings/Flange-Mount-Bearings/1-4-BOLT-FLANGE-BEARING-W-LOCK-COLLAR-1-205-16-4-C.axd Not sure how they'll hold up to moisture and the salt but gotta be better than those bronze bushings. Share this post Link to post Share on other sites
HorseFixer 2,012 #6 Posted December 4, 2013 (edited) John, I brought the specs up on that bearing and the thickness Measurement "B" is 1.807 and on each side I have about 1.375 clearance on each side. So some modification will need to be done to accept that size bearing either on the blower shell or something maybe the bearing could be mounted on the exterior but that will require cutting a larger opening on each side. I wonder if a thinner bearing is available? Well it figures anything I get involved in usually ends up to be a bunch of extra work! ~Duke Edited December 4, 2013 by HorseFixer Share this post Link to post Share on other sites
wallfish 16,038 #7 Posted December 4, 2013 How about the one without the collar and shave a little off the edge or the back? Still locks to the shaft. http://www.surpluscenter.com/Power-Transmission/Bearings/Flange-Mount-Bearings/1-4-BOLT-FLANGE-BEARING-1-205-16-4.axd Share this post Link to post Share on other sites
HorseFixer 2,012 #8 Posted December 4, 2013 Now that one right there I think will work. In would also use some Loctite 660 Slip Fit Compound http://www.loctite.ph/php/content_data/LT4680.pdf This would help on worn shaft. Thanks John ~Duke Share this post Link to post Share on other sites
wallfish 16,038 #9 Posted December 4, 2013 I'm onboard. It just seems way to easy for dirt to get into that bronze bushing and just grind them away. Have you used that 660 compound before? It's pretty expensive Share this post Link to post Share on other sites
CTBT&D 77 #10 Posted December 8, 2013 I used self centering sealed ball bearings with a locking collar and flanges from TSC. Also made a 1/4" spacer as seen in the photo. Craig Share this post Link to post Share on other sites
