TravelinJavelin 621 #1 Posted December 1, 2013 I'm looking at maybe another machine to mount my plow on to and wanted to know if a long frame plow would fit a 71 raider or charger? Share this post Link to post Share on other sites
Sparky-(Admin) 24,658 #2 Posted December 1, 2013 I think those machines (1971's) are long frame tractors.....so yes it will work perfectly. Mike............. Share this post Link to post Share on other sites
TravelinJavelin 621 #3 Posted December 1, 2013 Awesome thanks just wasn't sure? Share this post Link to post Share on other sites
sorekiwi 761 #4 Posted December 1, 2013 All you ever wanted to know about snow plows: Share this post Link to post Share on other sites
TravelinJavelin 621 #5 Posted December 1, 2013 ok another ?? now that I've looked at the plow frames and determined I have a 520 plow frame with the extension now I haven't messed with it yet but can the extension be taken off and used on standard models from 73 up? Share this post Link to post Share on other sites
Sparky-(Admin) 24,658 #6 Posted December 1, 2013 Yep, couple pins on the rear part, a single bolt on the lift piece and its off. Heres where you will have an issue, the angle lever in the 520 extension kits was bent back toward the operator, no fixing that except replacing it with the correct one. I bet one of our used parts vendors right here on Redsquare can hook you up tho. If you never plan to purchase a 520 you might consider selling the extension parts, those kits when complete with all three parts bring good money. Mike...... Share this post Link to post Share on other sites
TravelinJavelin 621 #7 Posted December 1, 2013 so your saying the lever that the lever that you release with the cable is the one that's not going to fit correct or the lower rod to angle the plow? Share this post Link to post Share on other sites
Sparky-(Admin) 24,658 #8 Posted December 1, 2013 The lever that you grip with your hand is the one thats going to be to far back. About 4" I think. It might work but the ergonomics will be lousy. Mike.......... Share this post Link to post Share on other sites
squonk 45,589 #9 Posted December 1, 2013 Take off the extension and mount it and try it out. I think it would work. Good enough for my taste anyway Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #10 Posted December 1, 2013 One of my dozer blades was kitted for a 520. I removed the extensions but kept the offset lever and it works great on my 416 and GT-1848. When the blade is angled fully to the right, it's easier to reach the lever. I'm not too sure about footrest interference on the earlier tractors. 1 Share this post Link to post Share on other sites
953 nut 64,257 #11 Posted December 1, 2013 If you are using a manual PTO clutch rather than electric you may need to remove the engagement lever and top bracket to be able to use the blade angle lever. Good luck and Share this post Link to post Share on other sites
Scotsman 46 #12 Posted December 17, 2013 If the long frame didn't fit I would trade you my 6-2132 which is made for yours.....and yours for my 312-8first I live in Massachusetts. Your in Maine...... Share this post Link to post Share on other sites
TravelinJavelin 621 #13 Posted December 18, 2013 well I got mine to fit and works great I never had a tractor that could do as much as this thing does and it will push a lot of snow I was really impressed this last storm we got 14" where I live and once I was able to get some runs with it and would literally push it up hill but I got to greedy and broke some pins and hardware and no one was open so I threw on the snowblower and snow went away, very impressed! Share this post Link to post Share on other sites
