KC9KAS 4,746 #1 Posted November 27, 2013 Just picked up 5--30# vibration dampeners for a CAT diesel. Think they will make good wheel weights? 2 Share this post Link to post Share on other sites
953 nut 69,825 #2 Posted November 28, 2013 If the center hole will go over your hubs just drill a few holes, get some bolts, you have it! I bet they cost a lot less than the cast iron ones. Share this post Link to post Share on other sites
oldblue1993 99 #3 Posted November 28, 2013 Thats a pretty good idea, startin to think of some weight myself. Share this post Link to post Share on other sites
over60pirate 24 #4 Posted December 24, 2013 I took a 1/2" x 2" piece of steel, and welded a 1" section of barbell bar, to it. Then drilled a hole in each end and bolted it to the wheel. Behind the 50# weight are 35#'s. You might bake a center sleeve to use this method. Removing weights is fast. Share this post Link to post Share on other sites
