Dkphillips 22 #1 Posted November 24, 2013 Being a "newbie" to tractor restoration I am interested to see if anyone uses sand/soda blasting to remove paint, etc from their tractor parts. I have used sand blasting equipment in the past but not on anything that I was going to paint with a good finish like a tractor. Also if you have used these methods what type of media did you use? Any help would be greatly appreciated. Share this post Link to post Share on other sites
squonk 45,526 #2 Posted November 24, 2013 When I used to blast, I used glass beads for most of it. Now, I take my stuff to a local guy that does it and uses glass. I had him do a 704 hood and when I got it back it looked like it was just stamped out of the metal shop. Share this post Link to post Share on other sites
Dkphillips 22 #3 Posted November 24, 2013 Thanks Mike. I have never used glass but may give it a try. Share this post Link to post Share on other sites
Shynon 7,543 #4 Posted November 24, 2013 I use black blast (coal slag) from big box store. Have a blasting cabinet and blast all parts that fit. Send frame, hood and fenders to a friend to have blasted. Share this post Link to post Share on other sites
rmaynard 16,866 #5 Posted November 24, 2013 I use the 80 grit glass beads. Share this post Link to post Share on other sites
dclarke 4,117 #6 Posted November 24, 2013 I use the 80 grit glass beads also and get along good with them. Share this post Link to post Share on other sites
limited12 360 #7 Posted November 24, 2013 I just bought a soda blaster from Harbor Frieght, easy set up, easy to use, done a great job. I do need to go get a cabniet, its a little messy with out one. Welcome to Red Square Share this post Link to post Share on other sites
shorts 182 #8 Posted November 24, 2013 Do Not use sand for blast media unless you are using a make up air respirator system, sand can lead to silicosis In the lungs, kinda like the problems from asbestos, just about anything can be used for media depending on what's being cleaned and what results are required, Black slag in different grits, glass beads, baking soda, CO2, walnut shells, plastic beads, ground up corn cobs, steel shot, dry ice, etc Share this post Link to post Share on other sites
