wheelhorse66 10 #1 Posted November 18, 2013 my 1056 keeps shutting off all at once after you ride it for about 5 minutes,could it be that the battery keeps dieing and killing the motor because it dont have a voltage regulator on it, it has a 8hp kohlor on it Share this post Link to post Share on other sites
953 nut 63,896 #2 Posted November 19, 2013 As long as the battery has some voltage (don't even need a full charge) it should be enough to make a good spark. I would check the points and put in a new Champion H-10 to begin with. Also, take a good look at the gas filter. Hope this helps. Share this post Link to post Share on other sites
WH nut 553 #3 Posted November 19, 2013 Does it restart, or do you have to charge the battery or let it cool? Share this post Link to post Share on other sites
wheelhorse66 10 #4 Posted November 23, 2013 i have to jump it every time, but it will start right back up and then shut off, i dont think the battery has enough juce to run it and keep spark, is there any way to run it without a battery? Share this post Link to post Share on other sites
WH nut 553 #5 Posted November 23, 2013 Without a regulator on it you aren't charging the battery. First things first. Get a regulator on it and make sure its charging and see what it does. If it still dies we can work from there Share this post Link to post Share on other sites
rmaynard 16,836 #6 Posted November 23, 2013 With no battery, you would need an alternate constant source of 12 volts to supply the coil and keep it running. With no regulator, your battery charger/jumper is supplying that voltage. The only engines that run without a battery are those with a magneto. Share this post Link to post Share on other sites
