davedean
Onan 16 hp. dies after running
davedean
My 416-8 starts, runs and dies after a few minutes. It has been progressively worse over 4 days (not running every day). It would start and run for a half hour or so, then just lose rpm and die. I'd give it a short rest then it would start right up and run. The intervals of running/dying have been  getting shorter. The last time I tried, it would run about 10 mins. and die, and would not start back up. I think carburetor, any clues/suggestions?
Thanks for any input.
Dave
rmaynard
Be sure that the vent on the gas cap is not clogged.
Sparky
Before you rip into the carb, start back at the fuel tank. The tank needs to be vented to work properly so try running it with the fuel cap loose. If thats not it then maybe the fuel shutoff at the tank is the problem. It has a small mesh filter screen that can get clogged up with crap, might be time to swap it out. Do you have a fuel filter? How long has it been in service?
It could be the carb still but I would start with these other items first.
Mike..........
davedean
The see thru fuel filter is full of gas, but I noticed at one time the filter was almost dry. I'll try all the "easy" fixes first. The fuel hose coming out of the tank looks cracked, but not leaking.
Thanks
Dave
Edited by davedean
Martin
if the fuel system checks out ok........
ignition could be giving you problems, immediately when it stops check for spark. older ignition components can be unreliable. not saying thats the answer but would be the next step if you can't find the issue........
davedean
it won't start at all now, unless I spray starter fluid into the carb, As soon as it uses the fluid it dies. The foam filter was pretty dirty, not oil soaked. I blew both the foam and paper out w/ compressed air. I bet it's time to pull the carb, what do you think? I checked the fuel pump, it's working.
Edited by davedean
Martin
Sounds like the ignition is good then. I think you have a blockage in the fuel system somewhere. The carbs are easy to check for junk in the bowl, if you are careful removing the top of the carb, the gasket could be saved.
Take a look at my 416 adventures thread, I had fuel issues and managed to clean out the carb with it still on the engine.
Sent from my iPhone using Tapatalk
WH nut
I would pull the fuel line off the outlet of the fuel pump before I start ripping anything apart
davedean
I called the previous owner about the problem, he told me to change the inline fuel filter. I blew though the old one and it seemed clear, but the new filter fixed it.
Thanks everyone for all your help.
Ken B
Now I'd give your fuel tank a good cleaning and replace the fuel lines if they haven't ever been done....
davedean
I will do that. A little extra insurance is good peace of mind. What do you suggest would be a good cleaner for the tank? Thanks to everyone who posted
Edited by davedean
dennist
post-3300-0-57452800-1386086027_thumb.jp
Any above options are great, I tried them over and over. My worker 416-8 made me pull my hair out, it may not turn out to be any of the above issues, yet any one of them could make your problem happen.
I got pretty good at tearing apart all tin, exhaust, intake, carb, replacing fuel lines, pump and filter, removing/cleaning tank, new intake gaskets, then started with electronics...key switch, coil/plugs/wires, ignition module, trigger, jumped every safety switch, etc. Each and every time it would start and I swear it sounded better and ran smoother, but when I would get on it and drive for a few minutes it ran terrible and would die out. Some times it would smoke like a train and other times just seem like it was going to blow on me, but every time after sitting it would start and run smooth....common sense was telling me one thing, but the thought of running over it with a dozer was really looking good to me, And I mean it!
I had it with that darn Onan and finally felt like others on here feel about them, but I could not walk away and let it win me, I atleast wanted to tear it apart to see what was making it run that way. All the wires looked fine, compression was around 115psi on both sides. Finally looking in the same places as earlier right behind the upper steering shaft I pulled the wires completely out just to reassure myself that it had nothing to do with those and......
Lets just say "I" personally can not put the blame on those darn Onans, atleast not this time, although every time someone talks negative about an Onan I somehow link the engine with the non engine tractor issues. Good luck and keep the keys out of the dozers until you get it fixed!
post-3300-0-18949900-1386086448_thumb.jp
WH nut
He said a fuel filter took care of it, but you did have your hands full dennist, good find
varosd
Good post Dennist!
Davedean,
                 all above replys are great!  not sure if someone asked but is your 416-8 a Kohler or Onan engine? My 520 had sorta same issue, I tracked it down to the fuel tank. while I had fuel spurting into the carb. I replaced fuel lines/filter and pulled the gas tank out and lo and behold, as I drained the remaining fuel..the in tank filter was all plug up. I kept just adding fresh gas and did the gas tank Rock and Rye shake.  kept doing this and also opened up the drain and let fresh gas flush out (or just buy new drain plug)
started right up.   If it's an Onan, they do have carb issues.
wheeledhorseman
Having read the thread, and owning a !6hp Onan powered horse, there's a little mystery here in that when an Onan is running short of fuel in the carb bowl it starts hunting before the fuel runs out and it stops. All small engines with a governor do this to some extent but it seems to be very pronounced with an Onan yet it was not mentioned in the symptoms.
Hope it stays good for you now :handgestures-fingerscrossed:
Andy
  • Similar Content
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
    • BrianStasC-101
      By BrianStasC-101
    • Tenday
      By Tenday
      Experts - help please. I’m new to Wheel Horse Tractor life!
      So - I’ve pulled out an inherited tractor and have decided to resurrect her. Unfortunately, no spark :/
      I’m looking for help on diagnosing no spark.
      model - 417-8
      engine - Kohler KT17
      Done thus far:  (aware that some have no implication on spark.)
      - new ignition switch
      - new battery
      - new starter
      - new ignition coil and wires w/ plugs
      - new condenser
      - new points
      - new starter solenoid
      - bypassed all switches except oil and seat.
      notes:
      idiot lights removed.
      All fuses tested with Ohms as well as visual inspection  ..
      coil tested w/ ohms as well
      all switches bypassed except:
      -oil switch  ( don’t think it has any implications other than a visual indication for idiot lights. )
      -seat switch
      ran a pos from batt direct to pos of coil - nothing; no spark.
      Electric is as follows:
      - Starter switch wired to solenoid
      - - solenoid to starter
      - - solenoid to batt
      - one wire from starter switch goes to engine ( I think this is for batt charge / flywheel)
      - I have two yellow wires, which are married up, that go to engine which have constant power; They power coil.  Comes from switch and seat.
      Help - what the heck am I missing ?
