bustedglass 2 #1 Posted August 30, 2008 Hi Guys, I need an ignition switch for my newly found 414-8 tractor. The TORO parts finder page shows a Part # 111215 Switch needed. There is a Part # 111216 Switch on fleabay. What is the diff. ? And, can I use the Part # 111216 Switch ? Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #2 Posted August 30, 2008 111215 superceeds to 103991, Mike. That is a 5 prong switch for magneto ignition. (correct for the Magnum engine) It's actually the same switch that's in your 211. The 103991 switch is also available aftermarket. (Stens has them) Under no circumstances should you substitute another switch - BAD things can happen if you do. :banghead: Share this post Link to post Share on other sites
bustedglass 2 #3 Posted August 30, 2008 Thanks TT. You are the best. Sure is good to have you here again. Your job gets in the way . Share this post Link to post Share on other sites
