Zeek 2,284 #26 Posted November 30, 2013 If you are a newbie to spraying, any gun is going to suffice. I have used the HVLP sprayers from Harbor freight with good success. For $15.00 you can get one, play with it, use it and throw it away when done. It's cheaper than a gallon of lacquer thinner needed to clean it. I do the exact same and have had excellent success with those guns. Share this post Link to post Share on other sites
zanepetty 117 #27 Posted November 30, 2013 I bought a HF gun. I got the nicer purple one. I was reading reviews and they said the tip and nozzle were actually machined and it has more of the small holes in the tip for better paint distribution. (Can't remember what they're called at the moment.) Share this post Link to post Share on other sites
zieg72 209 #28 Posted November 30, 2013 Good choice for an inexpensive spray gun. I have one customer that buys them by the case. They get 6-8 months out of one used in production every day and really like the atomization quality. 1-2 in a case don't work but HF replaces them no questions asked. Share this post Link to post Share on other sites
zanepetty 117 #29 Posted November 30, 2013 HF has always done me right. No complaints there. I think I'm really going to like it. I bought the small purple touch up gun yesterday for around 9 bucks on sale. Just thought I'd try that. Share this post Link to post Share on other sites
Save Old Iron 1,563 #30 Posted November 30, 2013 the tip nozzle size on the typical detail gun is usually under 1mm. a small tip will not allow sufficient atomization of thicker enamels and will require over thinning of the enamel paint with reducer. over dilution of enamel causes low gloss. a 1.2 to 1.4mm tip will be your best bet. 1 Share this post Link to post Share on other sites
zanepetty 117 #31 Posted November 30, 2013 Oh OK. Good to know. Guess I waisted my money on that one :/ Share this post Link to post Share on other sites
buckrancher 2,678 #32 Posted November 30, 2013 I use these Brian Share this post Link to post Share on other sites
Save Old Iron 1,563 #33 Posted November 30, 2013 Oh OK. Good to know. Guess I waisted my money on that one :/ i use that size nozzle to spray etch primer. works great for priming smaller parts with the thinner lacquer based self etch primers. high build primers need a 2mm or larger tip. Share this post Link to post Share on other sites
zanepetty 117 #34 Posted November 30, 2013 I thought about buying those Brian. They work well? Share this post Link to post Share on other sites
buckrancher 2,678 #35 Posted December 1, 2013 I thought about buying those Brian. They work well? yes I have had good luck with them . all my show tractors were painted with those guns and I use the touch up gun with the 1mm tip for spraying color both urethane or base coat clear coat finishes 1 Share this post Link to post Share on other sites
zanepetty 117 #36 Posted December 1, 2013 Wow. Looks awesome! I thought you mostly used single stage paints? Share this post Link to post Share on other sites
buckrancher 2,678 #37 Posted December 1, 2013 Wow. Looks awesome! I thought you mostly used single stage paints? I do all tinware with basecoat clearcoat all the rest with single stage. The exception is my 854 I did that with single stage paint Brian Share this post Link to post Share on other sites
zanepetty 117 #38 Posted December 1, 2013 Oh OK I gotcha. Share this post Link to post Share on other sites
eb in oregon 28 #39 Posted December 3, 2013 I'm not trying to be "a spoiler" here, but you do realize that if you were to just "rattle can" it, it would probably be as good as the original factory finish? Anything you do (except for runs) should be just fine. If you are "showing" your product, the problem is judges that imply higher standards than the original. I dislike that, but it is hard to argue with them. Share this post Link to post Share on other sites
Uncle Buck 246 #40 Posted December 3, 2013 I am not recommending the following, but I will share how I painted an old pickup one winter in an old drafty garage when most of the winter the temps stayed below freezing. I am not suggesting you should follow my lead, but I will say that the paint I put on that old truck that winter 1994 is still shining and sticking to the truck to this day. I used regular acrylic enamel with hardener for my paint job. Each night I would walk in that old drafty detached garage and fire up a torpedo heater. Generally I turned on the heat around 5:30pm. I would do prep and body work throughout the evening never using any primer, paint or other flammable and fumy painting materials. Only filling sanding and sheet metal work throughout the evening. I kept my paint, gun, reducer, hardener etc. in the warm house. I would tape off and prep a panel for prime or paint and once it was all ready I would go to the house and mix my paint. The compressor would already have the moisture drained when I brought the gun back to the garage with me. I would immediately turn off the heater, plug in the gun and spray the prepped panel. After I was done the fumes would be hanging too heavy in the air to restart the heater so I would clean my gun up and call it a day. With the heater turned off it did not take long for the garage to lose the warmth so every panel I sprayed that way ended up drying in below freezing temps. I had little choice so that was how I painted the truck and I just took my chances though I knew the freezing temps might ruin my paint job in the end. Amazingly though that did not happen. The vital point is I suggest being careful of your choice of shop heat when you spray or even brush paint for that matter. Open flames make great sploshuns you know! Share this post Link to post Share on other sites
zanepetty 117 #41 Posted December 3, 2013 Wheel horse didn't even use primer! So these tractors are getting pampered when the get ANY kind of paint! Share this post Link to post Share on other sites
