SMITTY
KOHLER VOLTAGE REGULATER
SMITTY
Anyone know the part # for the regulator on a K241 with starter generator?
gwest_ca
I looked up K241-46333 here
http://www.partstree.com/parts/
and the 4th starter/generator page shows voltage regulator # 275746-S which has been discontinued by Kohler. What are your engine numbers?
Garry
SMITTY
Thanks for the reply Gary
It is a k241 46330 Serial 0165466. Started it yesterday and Starter whould no stop until removed wire from regulater.
Smitty
gwest_ca
k241-46330 uses the same 275746-S regulator.
Here is an old Kohler manual that covers the starter/generator
This Stens dealer is in Ontario Canada but I like their site
http://www.bantasaw.com/
Take a look at 435-040
Garry
Save Old Iron
If you are interested in a possible temporary fix, remove the (+) battery cable from the battery and then remove the cover of the regulator. . You may find one set of relay contacts stuck or welded together. From your symptoms, I suspect the cutout relay contacts are welded together.
You can GENTLY pry apart the contacts and use 400 - 1000 grit wet / dry sandpaper to polish the pitted contacts. Again, this will be a temporary fix as the tungsten coating is probably vaporized off the contacts, allowing them to stick together.
Edited by Save Old Iron
SMITTY
Thanks for the replys found a replacement locally
  • Similar Content
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
