Rideking 32 #1 Posted November 7, 2013 The K241s in my '86 310-8 is starting to smoke quite a bit and needs to be rebuilt. However I have what I believe to be a K241AS from a c-101 with the isolation type motor mount oil pan. Is there an easy way to swap the oil pans between the 2 engines (I don't have the isolation motor mount brackets). Ideally I'd like to put the K241AS in the 310 while the original motor is at the machine shop being rebuilt so I'm not left without a tractor to power my snow blower in the event of a snowstorm! Share this post Link to post Share on other sites
rmaynard 16,552 #2 Posted November 7, 2013 (edited) The short answer is NO. The S engine oil pan cannot be placed on the AS engine block and vise-versa. Edited November 7, 2013 by rmaynard Share this post Link to post Share on other sites
Rideking 32 #3 Posted November 7, 2013 If I could find the "shaker" style mounting plate for the K241AS engine would it bolt up? Share this post Link to post Share on other sites
Fordiesel69 271 #4 Posted November 7, 2013 You can remove the belt guard and bolt the entire isolation mount system in place of your solid mount. Then bolt the engine to the isolation mount. The belt guard is different, and some hole are not in place on certqain frames. If you do not have a spare isolation mount, you cannot just swap pans. The base of the block is different. Share this post Link to post Share on other sites
rmaynard 16,552 #5 Posted November 7, 2013 If you do find a cradle, be sure to install all the necessary grounds. Since the cradle is isolated from the frame,a ground must be established between the block and the cradle (mounting bolts), cradle to frame (wire), battery to frame (wire). Share this post Link to post Share on other sites
Trouty56 567 #6 Posted November 7, 2013 Just need to get creative.....think a little bit.....make some brackets.....and bolt it to the frame..... Share this post Link to post Share on other sites
Lagersolut 746 #7 Posted November 8, 2013 Just restored a C-101 ( K241AS ) this year , I mounted everything to the cradle " BEFORE " I mounted it on the tractor - the engine to cradle mounting bolts are too long and right over the frame when on the tractor - also the isolation mounts/cradle don't mount directly to the frame - there are two angled mounting ( one at each end ) blocks bolted to the frame the mounts sit on and bolt to. I had to loosen the blocks a little to get all my bolts started . If you need a picture or two let me know, # 25 & 22 parts list http://www.partstree.com/parts/?lc=toro_consumer&mn=91-10K802%2C+C-101+8-Speed+Tractor%2C+1979&dn=810118R1-18R10038-00018 Share this post Link to post Share on other sites
Rideking 32 #8 Posted November 8, 2013 Went out to the barn tonight to look at the engine, it appears that I have the mounting plate but not the cast blocks (#22 & 25) and the rubber mounts. Does anyone have the a measurement from the top of the frame to the bottom of the engine mounting plate so I can see if I can fab up a mounting block? Share this post Link to post Share on other sites
Lagersolut 746 #9 Posted November 8, 2013 (edited) Went out to the barn tonight to look at the engine, it appears that I have the mounting plate but not the cast blocks (#22 & 25) and the rubber mounts. Does anyone have the a measurement from the top of the frame to the bottom of the engine mounting plate so I can see if I can fab up a mounting block? 5/8 " from the top of the frame to the bottom of the cradle - check around here - you may find someone who has a set - save a lot of work - take note though the C-111 on the parts list is different than the other models - what and why I have no idea My measurement is off my C-101 . Edited November 8, 2013 by Golds-Red Share this post Link to post Share on other sites
Lagersolut 746 #10 Posted November 8, 2013 Let me know if you need other measurements - I'll check back tomorrow - off to bed for now . Share this post Link to post Share on other sites
Rideking 32 #11 Posted November 8, 2013 Thanks for the measurement, I'm hoping other than making / finding a couple brackets that this is an easy swap! Share this post Link to post Share on other sites
Trouty56 567 #12 Posted November 8, 2013 I went with a couple 3/8 inch by 1 1/2 inch flat steel....cut 4 pieces to the width of the frame.....bolted 2 to the bottom of the oil pan with a 1/8 washer between....then I lined up the pto hoop and positioned the other 2 pieces where existing bolt holes were.and clamped them tight..... sprayed paint under the frame where the holes needed drilled.... Then bolted it all together......positioned things with the pto hoop again and welded the cut pieces in place..... Total height off the frame was 7/8 inch......5/8 from the frame to the bottom of the plate and 1/4 inch plate.....Rube Goldberg but .... Honestly it isn't in the tractor yet but I'm pretty sure it will bolt right on when the time comes.... Share this post Link to post Share on other sites
Rideking 32 #13 Posted November 10, 2013 Trouty - any pictures if your setup? Share this post Link to post Share on other sites
i967mustang 21 #14 Posted November 10, 2013 I had a similar problem with a C160 where the block was different and I had to raise the engine 3/4" and redrill the frame to mount it. I didn't have the original block, as it was blown up when I got it and was a 14 hp instead of the 16 that belonged on it. I found a 16 hp from a wheel horse and bought it not knowing that the base was different but I made the spacers and redrilled the frame and bolted it down. Has been on since half way through the summer and is fine. Share this post Link to post Share on other sites
Trouty56 567 #15 Posted November 10, 2013 (edited) Trouty - any pictures if your setup? Like I said... Rube Goldberg.... Edited November 10, 2013 by Trouty56 Share this post Link to post Share on other sites
posifour11 723 #16 Posted November 10, 2013 That's not bad. Looks like the mount for a 181 on the 70s tractors Share this post Link to post Share on other sites
Shuboxlover 481 #17 Posted November 11, 2013 I have a complete iso mount setup if you are interested??? Share this post Link to post Share on other sites
