russtiron
`55 Cable Steer project
russtiron
Hi all  I have a project tractor and have a couple of questions.The steering shaft has been cut to adapt another steering wheel and I was wondering if the steering shaft length is the same on the early cast wheel and the later regular wheel,also the front wheels have been replaced ,I know early tractors have a narrow rim,does this continue through the rj59`s? Thanks!  Chuck
buckrancher
basicly all wheel horse tractors used the same style and size front rim up to 1964( with some exceptions) and yes I believe the steering shaft lengh is the same for both cast and steel spoke steering wheels on the RJ's
Brian
AMC RULES
:scared-eek:  Cable steer you say?
           :wwp:
stevebo
The front rims on the RJ35's had a very small "lip" on the rim whereas the 58's and on had the larger lip.
Jake Kuhn
post some pictures of your rims....from what I remember they looked like the right ones?
953 nut
There is a post on here for the 2014 calendar, one of the listings is made by "VinsRJ" and it is a '55 Cable Steer with lots of great photos. I bet if you sent him a PM he would overload you with usefull information.
ps.         :text-worthless:                :wwp:
Edited by 953 nut
russtiron
This is a different tractor.I have another 55 that I think has the right rims but they don`t seem as wide as later rims.  The tires are marked Sears and are smaller,the rim is also too narrow for the spindle.Chuck
post-9417-0-98550200-1382920272_thumb.jp
post-9417-0-54905100-1382920352_thumb.jp
post-9417-0-24162700-1382920423_thumb.jp
VinsRJ
It looks like you have a nice RJ there! These early machines are the coolest!
Wheel Horse Kid
Great looking RJ!
  • Similar Content
    • CasualObserver
      By CasualObserver
      Operator manual
      Illustrated parts list
      6 pages 3.73MB
      Illustrated parts list #A-7136
      Includes PSB #023 #052 #058 #060 #080
      10 pages 938.48KB
      Engines used according to Toro
      Clinton B1290-1107
      Kohler K91-31307A
      Kohler K91-31388A
      Electric start kit
      Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
      Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
      6-12 tire chains model TC-12 - Listed for 1958 and 1959
      Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
      Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
      Details & Attachments
      2 pages 107.33KB
      1958 model RJ-58
      1958 serial numbers that have shown up for the RJ-58
      Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      00005
      00251
      01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
      01188 - Has round rear wheel hubs
      01516
      01636
      01768
      01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
      01797
      01871
      02525
      03177
      03501 - Located in UK
      03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      04041
      04883
      04885
      05000
      05619
      05714
      05798
      06528 - May be 16528
      06749
      06771
      07633
      07649 - Transmission J12-8 October 12, 1958
      07725
      08440
      08612
      09284
      09337 - Hard to read
      10163
      11432
      11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
      11916
      12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
      12291
      14473
      14713
      16097
      16528 - May be 06528
      166x6
      16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
      18348
      June 2023
      18500 and lower
      Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      2 pages 106.94KB
      1959 model RJ-59
      1959 serial numbers that have shown up for the RJ-59
      Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      18501 and up - Possible 1100 units built
      20078 - Located in UK
      203xx
      21033
      292xx
      21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
      Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
      K91T-31388A Serial 425251 found on RJ-59
    • bigbuck
      By bigbuck
      I'm not positive of the model, but I think I'm close. Please call George at 517-499-5678
    • RJcollector
      By RJcollector
      Ive been thinking about selling my 4 RJ-58s and all the attachments and parts I have. I have 4 tractors-2 have Kohler K91T , 1 has the Clinton and one has no engine. Only 1 is missing the serial number decal. Kohlers run. Clinton needs a carb. I have original exhaust shields AND belt guards for 3 of them. 3 mower decks, 2 plows, cart, 2 spare transmissions, parts breakdowns, original manuals and sale tags, seats, tires.  Not sure if I should sell it as 1 big collection or break it up. And also a good starting price?  I'll post pics when I get a chance. Thanks
    • Keaton
      By Keaton
      i do not know how to route this throttle cable on this RJ 59, i will attach some pictures, i watched packrats video on adjusting the govner on his 401, it did not look the same. also i think that and is way to long so that might be part of it. ( and also the color on that block looks beautifull) there is come pics, the more the better!
