whtractors24 3,572 #1 Posted September 19, 2013 953 there are 3 belts the drive, lift, starter gen belt how can I find out diamater and length of each to have spares on the shelf? Any help is appreciated Share this post Link to post Share on other sites
"D"- Man 827 #2 Posted September 19, 2013 (edited) I just measured my N.O.S. genuine Wheel Horse belts. The 1591 is 3/8" x 47" the 1592 is 1/2" x 81-3/4" the 1593 is 3/8" x 34-1/16 (All length measurements were taken on the outside of the belts.) Just to compare I measured my used starter/generator belt and the outside length was 34-3/8" so it may have "stretched" with use. These (953/1054's) that also have a mower deck use a 1594 or 1595 or both. Mark Edited September 19, 2013 by TWIN54 Share this post Link to post Share on other sites
whtractors24 3,572 #3 Posted September 19, 2013 Thank you now can you tell me 1951 is what belt and so on. Ill save this. Share this post Link to post Share on other sites
"D"- Man 827 #4 Posted September 19, 2013 Yes, although it is fairly self explainitory, as one will not fit in the wrong position. The 1591 is the 953/1054 Hydraulic pump to engine inner(smaller diameter) pulley, the 1592 is the 953/1054 Drive belt this one goes on the outer (larger diameter) engine pulley, the 1593 is the starter/generator belt which goes on the flywheel screen pulley and the S/G. The 1595 is for an RM-483 or RM-484 mower deck Drive, the 1594 is for an RM-483 or RM-484 mower deck Idler. Mark. 1 Share this post Link to post Share on other sites
