Stigian 1,235 #1 Posted September 4, 2013 Morning all, what would be the best all round type of "media" to blast with? I'm thinking mostly about blasting wheels at the moment. If you hadn't of guessed Any advice would be much appreciated. Cheers Share this post Link to post Share on other sites
meadowfield 2,953 #2 Posted September 4, 2013 e tank! 48Vdc power supply and lots of ventilation.... Share this post Link to post Share on other sites
VinsRJ 723 #3 Posted September 4, 2013 e tank! 48Vdc power supply and lots of ventilation.... I'll all done with the etank thing... its run its course with me... aside from a hood off a Round Hood WH... blast everything. Share this post Link to post Share on other sites
SousaKerry 503 #4 Posted September 4, 2013 (edited) I use coal slag, we get it here locally under the Black Beauty brand but I'm sure they don't export. It is cheap has no silica in it and seems to work very well. If you start with your cast parts first it will brake down a bit, and be less aggressive for your fender and hood. http://www.blackbeautyabrasives.com/products/black-beauty-original-abrasives.php Edited September 4, 2013 by SousaKerry Share this post Link to post Share on other sites
Stigian 1,235 #5 Posted September 4, 2013 (edited) e tank! 48Vdc power supply and lots of ventilation.... You might be on to something there Mark, ventilation is good as the the e-tanks out side, and there are handy mains power cables that runs above the shack and heads off to a barn... Now where did I put those jump leads? e tank! 48Vdc power supply and lots of ventilation.... I'll all done with the etank thing... its run its course with me... aside from a hood off a Round Hood WH... blast everything. I still love my e-tank, it's just that wheels still need a lot of hand finishing to clean them right up after e-tanking.. A media blaster would be a much faster way of getting the rims clean and it would reach all those "hard to do by hand" places.. I use coal slag, we get it here locally under the Black Beauty brand but I'm sure they don't export. It is cheap has no silica in it and seems to work very well. If you start with your cast parts first it will brake down a bit, and be less aggressive for your fender and hood. http://www.blackbeautyabrasives.com/products/black-beauty-original-abrasives.php Thanks for that. I've just found the Blackbeauty stuff on ebay, but as It's a USA seller the shipping costs are way too much. Edited September 6, 2013 by Stigian Share this post Link to post Share on other sites
SousaKerry 503 #6 Posted September 4, 2013 If you got any coal fired power plants around they may sell or give you some slag material but you would have to screen and crush it yourself. Just an Idea 1 Share this post Link to post Share on other sites
Anglo Traction 761 #7 Posted September 4, 2013 Me no Expert Ian, but familiar with what my 'Blaster' in Lingfield UK uses. Are you planning to use some kind of Cabinet and have a kind of Media Recovery system, or a total Media Loss?. Various grades of Oxide of Alumina are probably the cheapest (if your for total loss). They can wear out the Ceramic Nozzles pretty rapid though (coarse grit). I believe Walnut shell is available over here (not cheap), it's effective, gentle and eco friendly. Plastic or Glass bead usually used and recovered. The only drawback is cleaning it out of close or tapering joints. Share this post Link to post Share on other sites
KC9KAS 4,746 #8 Posted September 4, 2013 (edited) ARMEX (Arm & Hammer) soda blast.........http://www.harborfreight.com/50-lbs-medium-grade-armex-soda-blast-media-65929.html Plastic blast media........http://compomat.com/plastic-blasting-media Edited September 4, 2013 by KC9KAS Share this post Link to post Share on other sites
JimD 3,347 #9 Posted September 4, 2013 I used #10 glass bead on some rims and other parts. It works well but don't blast over 60 psi or you'll just be breaking down the media. Share this post Link to post Share on other sites
953 nut 63,789 #10 Posted September 4, 2013 Don't know if you have a Harbor Fraight in England, but if you do they have some low priced media blast cabinets and as JimD said I uas glass beads at 50 PSI and have great results and a clean shop. Share this post Link to post Share on other sites
Stigian 1,235 #11 Posted September 6, 2013 If you got any coal fired power plants around they may sell or give you some slag material but you would have to screen and crush it yourself. Just an Idea I like your thinking, I'm always up for recycling stuff.. Unfortunately there are no coal fired power plants anywhere near here.. Cool idea though. Me no Expert Ian, but familiar with what my 'Blaster' in Lingfield UK uses. Are you planning to use some kind of Cabinet and have a kind of Media Recovery system, or a total Media Loss?. Various grades of Oxide of Alumina are probably the cheapest (if your for total loss). They can wear out the Ceramic Nozzles pretty rapid though (coarse grit). I believe Walnut shell is available over here (not cheap), it's effective, gentle and eco friendly. Plastic or Glass bead usually used and recovered. The only drawback is cleaning it out of close or tapering joints. Morning Richard, I'm planning on using a blasting cabinet which should work out cheaper in the long run rather than a total loss system. There are a lot of different types and grade of blasting media available in the UK, strangely plastic beads is the hardest one to find. I can live with having to clean media out of tapering joints, it's got to be much easier than cleaning rust/old paint out of the same joint by hand.. ARMEX (Arm & Hammer) soda blast.........http://www.harborfreight.com/50-lbs-medium-grade-armex-soda-blast-media-65929.html Plastic blast media........http://compomat.com/plastic-blasting-media Thanks for the links, some handy reading there I used #10 glass bead on some rims and other parts. It works well but don't blast over 60 psi or you'll just be breaking down the media. Don't know if you have a Harbor Fraight in England, but if you do they have some low priced media blast cabinets and as JimD said I uas glass beads at 50 PSI and have great results and a clean shop. Thanks guy's, glass beads and about 50psi it is Share this post Link to post Share on other sites
Anglo Traction 761 #12 Posted September 6, 2013 There are a lot of different types and grade of blasting media available in the UK, strangely plastic beads is the hardest one to find. Hi Ian , Check this company out, they have what you may be looking for (Avialite Type V ), large choice of media types- http://www.macants.co.uk/ Share this post Link to post Share on other sites
specialwheelhorse 174 #13 Posted September 6, 2013 Aircraft Industry uses glass beads, Worked ten years there. The old goof in Texas Share this post Link to post Share on other sites
shorts 182 #14 Posted October 7, 2013 ground corn cobs are another option here in the Midwest, abrasive enough to clean things but not to hard on the base metal, pretty much environmentally friendly until you figure in the paint removed. Share this post Link to post Share on other sites
