papaglide 541 #1 Posted September 4, 2013 I have a pair of ag tires that are filled. How can I drain the anti freeze out of them? Share this post Link to post Share on other sites
jbumgarner 12 #2 Posted September 4, 2013 When I worked for Ditch Witch we would pull the inside out of the valve stems and let it drain out. It took a while but generally it worked to get 75% out then just break the bead to get the remaining fluid out. We had a wash bay we could sit them in so it wouldn't make a mess. Share this post Link to post Share on other sites
papaglide 541 #3 Posted September 4, 2013 Thanks, Jeff. I started draining one last evening and was disappointed at the lack of flow. I guess I will just need patience with these. Share this post Link to post Share on other sites
rwilson 128 #4 Posted September 5, 2013 could always drill a hole in the center of the tread and let it drain that way. Share this post Link to post Share on other sites
clemedc 29 #5 Posted September 5, 2013 use a drill powered pump and an adapter used to fill the tires. just pump out instead of in. Share this post Link to post Share on other sites
