big_ddawg
trying to find a deck belt for c-160
big_ddawg
I have been trying to find a deck belt for a c-160 with no luck the ID# is 71-16k802 , i am fixing it for a friend and i put new tires on it and got the motor running great but im having no luck finding a belt.he told me its a 54" deck i would realy appreciate any help , he is a Viet Nam Vet and realy needs this mower because of handicaps.
C-160 Auto
That's a 1977 year tractor. Do you see any numbers on the deck? More than likely it's a 42" deck. Is it side discharge deck?
C-160 Auto
It may be here (I'm doing this from my phone, so no guarantees! )
big_ddawg
its a side discharge , im gonna take the deck off tommoro and look for numbers "thanks"
gwest_ca
Mower decks are sized by their width of cut so model guess is likely close enough for belts. The deck you have could be older or newer.
1977 42" side discharge model 75-42MS01
Drive belt
Toro 102742 WH nla Use 94-2501 {HA/Ax103"}
6378 Gates 1/2"x103-1/4" 40 degrees
6378 Napa 1/2"x103-1/4" 40 degrees
Spindle belt
Toro 6738 {HA/4Lx86"}
6886 Gates 1/2"x86"
4L860W Napa 1/2"x86"
1977 48" side discharge model 75-48MS01
Drive belt
Spindle belt
Toro 1594 {HAx107.21"}
A105 Gates 1/2"x107"
A105 Napa 1/2"x107"
Garry
Adding - The parts lists at Toro are often shared by more than one model. In this case both decks are on the same pages. Some item numbers have different part numbers so it can be confusing as to what model uses what. The heavy reinforcement plate is only used on the 48" deck and the cover mounting screws go into the plate horizontally. The 42" deck cover screws go down into the deck pan.
daveoman1966
For width of deck, just measure the distance from the outside edge of the two gauge wheels.  OR....  just look at it.  A 48" deck has the height adj lever on the left side.  The 36 and 42" height adj levers are on the right side.
