Luke 9 #1 Posted August 28, 2013 Ok, so I'm tired of exhausting myself trying to start this old kohler engine for my boy. I think it's a k90. It's original in the 60' Suburban 400. Rather than rebuild, I'd like to replace it with a newer, more reliable engine that my boy can start on his own. Is there a new engine out there that will directly fit without modifying the hood or chassis? We measured the shaft with the pulleys still on, and believe it is 5/8. Are there any specs I should look for? I realize purists will shiver at replacing a working engine with a modern engine, but what good is the tractor, if my boy can't start it on his own. Share this post Link to post Share on other sites
Lane Ranger 11,964 #3 Posted August 28, 2013 That Kohler K90 should be an easy start motor. No new motor is going to easily replace the K 90. The Red Square gang can help you with getting it to run , parts, timing and or a rebuild if it is needed. Share this post Link to post Share on other sites
AMC RULES 37,259 #4 Posted August 28, 2013 So, when you're ready to get rid ot that tired old K90...let me know, I'll come get it. . 1 Share this post Link to post Share on other sites
buckrancher 2,696 #5 Posted August 28, 2013 shaft size should be 3/4" Share this post Link to post Share on other sites
Hodge71 691 #6 Posted August 28, 2013 (edited) That motor needs some attention if it wont start. You might try some serious troubleshooting. I have a Suburban 400 with the K-91. It is all original and has never been rebuilt. It didn't run when I got it ( I actually picked up 4 round hoods because the guy had no idea where to begin troubleshooting why they wouldn't start.) I rebuilt the carb, cleaned the points and that 400 fires up on the second pull every time. First pull, full choke, sputter, second pull starts right up unless its less than 20 degrees than it needs 3 to start. Putting a new engine is no substitute for finding whats wrong with yours. Its a skill you need anyhow if you're serious about these awesome old tractors. Edited August 29, 2013 by hodge71 Share this post Link to post Share on other sites
VinsRJ 723 #7 Posted August 29, 2013 A K90 would not be original for a 60 400, the motor should be a K91 with a 3/4" shaft... the correct SPEC No. I do not remember off hand (at work now). As for starting the small K-Series... it should fire easily. I would go through the entire ignition system from the points to the flywheel magnents with a process of clean or replace. Now on the subject of replacement motors, I have replaced a number of RJs and Suburbans with a Harbor Frieght clone engine (6.5hp). You will have to modify the clone engine's muffler system but other than that it fits under the hood of either model (RJ/Suburban) without need of modifying the hood or frame. Also the belt guards mount without modification. Share this post Link to post Share on other sites
bean 85 #8 Posted August 29, 2013 (edited) if you wanted to get a newer replacement, that somewhat keeps the original look, you could get a Honda gs160 . it is a lighter version of their commercial series Edited August 29, 2013 by bean Share this post Link to post Share on other sites
Luke 9 #9 Posted August 29, 2013 if you wanted to get a newer replacement, that somewhat keeps the original look, you could get a Honda gs160 . it is a lighter version of their commercial seriesuntitled.png I'm afraid the exhaust location of the Honda gs160 would be dangerous to the driver, considering the mounting location on a 1960 Suburban. Share this post Link to post Share on other sites
bean 85 #10 Posted August 29, 2013 (edited) that would be a problem Edited August 29, 2013 by bean Share this post Link to post Share on other sites
SousaKerry 503 #11 Posted August 29, 2013 Sounds like a good father son project to me to get the K-91 running again, I am sure you will both learn something in the process. Share this post Link to post Share on other sites
