Mike333 5 #1 Posted August 27, 2013 So my GT1100 shredded it's deck belt while mowing today and all I know about the deck is that it has 2 10 inch blades and one 11 inch blade. Any info on this deck and the belt size would be great, the old belt is in pieces so I can't really measure it to get a size. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,532 #2 Posted August 27, 2013 05-36MR02 is a 36" rear discharge deck. Mower blades 12-1/8" long Left & Right 14-1/8" long Center Decks are sized by their width of cut. Need to identify the deck to get the correct belts. Garry Share this post Link to post Share on other sites
Mike333 5 #3 Posted August 27, 2013 (edited) 05-36MR02 is a 36" rear discharge deck. Mower blades 12-1/8" long Left & Right 14-1/8" long Center Decks are sized by their width of cut. Need to identify the deck to get the correct belts. Garry There is nothing on the deck to identify it, it has been repainted several times and any identifying marks seem to be gone, unless they are hidden under paint, I hope... Thank you for the information on the blades, I am really in the dark, all I have is a OM, and that doesn't really tell me much, I also think I remember the guy I bought it from telling me it was not the original deck,but I could be wrong. Thanks again Garry, I really appreciate your help. Edited August 27, 2013 by Mike333 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,532 #4 Posted August 27, 2013 Did you look at the parts list here for the 05-36MR02? May not be your exact deck but the same style, size and application so belts will work. These decks often got a new model number each year because of some small improvement. https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro Operator manuals http://www.wheelhorseforum.com/files/file/904-mower-rotary-1980-1983-c-series-mowers-om-810306r1pdf/ http://www.wheelhorseforum.com/files/file/884-mower-rotary-36in-rd-1984-05-36mr02-om-810345r1pdf/ Any part number for the manual you have? Decks are sized by their width of cut - not the width of the deck. 05-36MR02 spindle belt Toro 8411 {HA/4Lx76.94"} 6877 Gates 1/2"x77" 4L770W Napa 1/2"x77" Drive belt Toro 102741 {HA/Ax96.6"} 6638BR Gates 17/32"x96-3/4" Wrapped 6638BR Napa 17/32"x96-3/4" Wrapped Garry Share this post Link to post Share on other sites
Mike333 5 #5 Posted August 27, 2013 Did you look at the parts list here for the 05-36MR02? May not be your exact deck but the same style, size and application so belts will work. These decks often got a new model number each year because of some small improvement. https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro Operator manuals http://www.wheelhorseforum.com/files/file/904-mower-rotary-1980-1983-c-series-mowers-om-810306r1pdf/ http://www.wheelhorseforum.com/files/file/884-mower-rotary-36in-rd-1984-05-36mr02-om-810345r1pdf/ Any part number for the manual you have? Decks are sized by their width of cut - not the width of the deck. 05-36MR02 spindle belt Toro 8411 {HA/4Lx76.94"} 6877 Gates 1/2"x77" 4L770W Napa 1/2"x77" Drive belt Toro 102741 {HA/Ax96.6"} 6638BR Gates 17/32"x96-3/4" Wrapped 6638BR Napa 17/32"x96-3/4" Wrapped Garry Hey Thanks again Garry, you have been a huge help!!! I should be up and running by the end of the day, Don't know what I would do without all the great people here at RED SQUARE, you guys are the BEST!!!!! Share this post Link to post Share on other sites
