greybeard 0 #1 Posted August 21, 2013 I need to find out the size belt my c-101 needs. It is the deck drive belt. It goes from the engine shaft to the deck. Could anybody help me?!?! I never know where to find this Kind of info out! Share this post Link to post Share on other sites
daveoman1966 3,882 #2 Posted August 22, 2013 (edited) The belt is in the mower deck manual. Find you mower deck model ID number first. With that, you can then find the drive belt number. Many of these take belt # 102742 or 94-2501 (new mnumber) but that is not always the case. Edited August 22, 2013 by daveoman1966 Share this post Link to post Share on other sites
greybeard 0 #3 Posted August 22, 2013 I have found only two sets of numbers. the serial number and a 4 digit number. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,133 #4 Posted August 22, 2013 I have found only two sets of numbers. the serial number and a 4 digit number. What are those numbers? What is the mower width of cut and side or rear discharge? Garry Share this post Link to post Share on other sites
daveoman1966 3,882 #5 Posted August 22, 2013 What size deck? 36", 42" or 48" wide. A 42" wide deck model # would look like 05-42MS02 . There should be a tag on the left rear side of the deck. Share this post Link to post Share on other sites
greybeard 0 #6 Posted August 22, 2013 it is a 36" rear discharge. the first number is 91-10k802-19369 the other number is 9085 my deck has no plate anywhere Share this post Link to post Share on other sites
daveoman1966 3,882 #7 Posted August 22, 2013 (edited) 91-10K802 is the tractor ID number. A 36" rear deck would look like 05-36MRxx A 36" rear discharge deck wants belt # 102741. That is for deck # 05-36MR04 Edited August 22, 2013 by daveoman1966 Share this post Link to post Share on other sites
greybeard 0 #8 Posted August 22, 2013 ok, where can I find this kind of information? Share this post Link to post Share on other sites
greybeard 0 #9 Posted August 22, 2013 is that 102741 number for the deck belt or the pto? cause i need the pto Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,133 #10 Posted August 22, 2013 Mower belt chart http://www.wheelhorseforum.com/files/file/1998-chart-mower-drive-and-spindle-belts/ Long model number for the mower deck is required. Belt dimensions are at the end. Garry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,133 #11 Posted August 22, 2013 ok, where can I find this kind of information? Toro Master Parts Viewer is the quickest. https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro Enter your 91-10K802 tractor model number. The next page has a link to the Attachment list on the right. The models listed were sold at the time the tractor was new. They sometimes list a replacement for the original and the one available when the list was made. Although there can be many models that would fit the belts are usually the same. For mower decks it was spindles/bearings that changed. Garry Share this post Link to post Share on other sites
