zanepetty
whistling starter
zanepetty
Hey there,
Last night when I turned the key on my tractor the starter whistled twice before it actually engaged and cranked the engine. Anyone know what that could've been? Thanks in advance,
Zane
KATO
  :ROTF: :ROTF:  seriously though :ROTF: :ROTF:  sounds like the bendix  is not sliding up the shaft when it is cranking
you probably need to remove it and clean and lube the shaft. hopefully  that is all !!
zanepetty
Haha not quite like that! But do I take off the belt guard to clean it?
SousaKerry
Easier to remove the starter usually 4 bolts and a wire depending on the engine brand.  When you get it out try to clean the shaft as best you can with electrical contact cleaner or even brake cleaner without taking it apart.  Use a dry lubricant such as powdered graphite or it will just gum up with dirt again in a short time.
If you have to take off the gear to get it cleaned properly be careful as the spring and internal parts will go flying and you will be on your hands and knees cursing.
You can bench test the starter with a pair of jumper cables and a battery to make sure you have it working properly but make sure it is well secured to the bench as they will jump right out of your hand.
squonk
Your link didn't load for me Craig, and by the looks of things it's a good thing it didn't! :)
zanepetty
Thanks. And its a Kohler. OK I'll take it off carefully and clean it. I really appreciate everyone's help on here! I'll have a lot more questions as time goes on haha.
  • Similar Content
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
