jmack
48" deck issue with d-180
jmack
I've been fixing up my D-180 the last few weeks and finally got a 48" deck.  I didn't have a belt for the PTO and bught a TORO Wheel Horse #102868 V Belt to get the deck hooked up.  Today I tested out the deck and it bogs down, starts to squeal, and looses momentum when it hits the grass.
Could this be a tension issue or do I have the wrong belt from the PTO?
Thanks
jusjeepn
Jonathan,  It sounds like either your PTO clutch is slipping or your belt is to long.  Since It sounds like it spins up ok with no load, I would suspect your PTO clutch.  You can give me a call if you want!
jmack
Well I replaced one of the center bearings on my deck yesterday and seemed to fix my issues.  After I brought the tension up on the PTO belt it snapped after one day of mowing.  My guess is the pulley's angel on the belt dug into the side and broke it apart.  Good news is I got a great deal on a replacement belt!
But now I have another question...
On my D-180, my Bell crank Assembly part #101000 on my hydraulic lift linkage seems to be off.  As you can see on the far left and right the snow thrower links are not in the same place.  According to my parts manual, it appears they're alined in the same position.  The issue I'm seeing is the right snow thrower link is hitting my mower deck right on the head.  Is this normal or would I need to service the bell crank assembly to aline to the left link?
tommyg
Something doesn't seem right. I took a quick look at mine and indeed, the blower lift arms are parallel. Yours looks 10 or 15 degrees off compared to the opposite side. I also noticed that the lift arm is set about a half inch outside the mower deck leveler arm. So there's no way they could contact each other no matter how high the deck is raised. If yours is hitting at that location, it could really throw the whole deck out of whack. I didn't think it was possible for that lift linkage to become misaligned. I thought everything was welded in position, but maybe I'm wrong on that. Have you done a close inspection to see if something was cracked?
coldone
No clearance problems on either of my Ds and the 48 inch deck. The bell cranks are aligned unlike yours.
Trouty56
There should be extenders on the rubber deck stops when the deck is attached to a D series tractor.  Also the lift link is too short....
The bell crank needs corrected also.....I don't know which angle is correct though.  You can probably tell which one has been rewelded....but I will see if I can get a correct angle today for you......
Edited by Trouty56
Trouty56
So here is a pic showing the stop extenders. You can also see the blower lift arms are.parallel and the deck lift mechanism.
jmack
All this is interesting being that I believed many of these decks were interchangeable to a certain extent, but I guess I was wrong.  I measured the difference between the two Wheel Horse decks I own and the tack-a-matics are slightly different in width.  Hopefully changing these out for each other will fix my problem.
I also noticed my bell crank seemed to be welded on both side which would make it almost impossible to fix.  In the drawings the bell crank is made of two pieces...why would you need to weld these together?  When I get some time I'll pull the whole assembly out and see what can be done.
J-Mack
Edited by jmack
Trouty56
The D series has a different width than the other tractors.  The carriages are basically the same....I change from C to D but the deck stops need extenders for the D and the front rod needs swapped out.....these are the parts for a D series......
post-1933-0-38956900-1336169806_thumb.jp
Trouty56
The bell crank is two pieces.....there is always up/forward force but not down/back force......this provides a "float".....A pin can be inserted to provide down pressure for snow blades or scraper blades.  Same for the rear 3 point.....
jmack
Good news then, I have these.  I already replaced the handle bracket, but haven't swapped out the bumpers.
Edited by jmack
  • Similar Content
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
