chrisd200(inactive)
D160 Onan electric clutch onto D180?
chrisd200(inactive)
Anyone know if a D160 (Onan) electric pto clutch will fit on a D180 (kohler) I dont think it will bolt up but I have never actually tried. Someone asked me this the other day so I figured I would ask the best Wheel Horse people on the planet :) Thanks for your help!
JackC
Don't think so.  I believe the crank shaft sizes are different for one thing. I believe the crank on the ONAN D160 is 1 and 1/8 the Kohler is thicker.
I wonder why they did not put electric clutches on the Kohler powered D180s and D200s?
chrisd200(inactive)
yeah the Onan is 1 1/8"
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
