glkssailor
Looking for ideas... mods that no tractor should be without
glkssailor
I would like to get a general sense of what modifications people have found to be most useful from a practical perspective. I have a C-105 and a GT1100 to work with.
bartl
I don't know whether you can consider them "necessary", or even "desired", but here are a couple things I did during the rebuild of my Charger10....
- I replaced some of the "low strain" bushings with nylon ones (like the seat pan pivot) and used clevis pins instead of bolts and nylocks for the seat pan pivot as well, to facilitate removal for service, as needed.  I also replaced the dash and console retaining screws with stainless socket head cap screws.
- In the dash where a switch would normally go for an electric PTO clutch, I installed a fuse holder and 15a fuse for the lighting and accessories.
- I installed a 4-post starter relay (solenoid) under the fuel tank pan vs. the original non-solenoid-through-the-ignition-switch starter wiring.
- I ran the wiring for the headlamps beside the magneto ground wire and enclosed them in plastic conduit instead of along the frame.
- I used fusible link from the battery+ to the ignition switch "B" terminal for additional protection.
- I had a missing rear lift tube so I cut down a rigid toilet supply line, which has a nice radiused end on it, and fits perfectly in the indent in the bottom of the tool box.
- I replaced the torn up seat with a high back unit I found on eBay that not only has a nice drain in it but has 2 slides with a locking lever to make quick operator adjustments.  The slides are adjustable so no new holes needed to be drilled.
- I replaced the OE-style Tecumseh round muffler with a small 1" ID unit probably intended for a Farmall Cub or the like with a rain cap.  I figure why not send the noise and fumes over my head...
It's still a work-in-progress......I'd like to find a suitable trio of gauges....tachometer, voltmeter and hourmeter.
SousaKerry
LED tail lights instead of reflectors.
jeremi3210
An old metal first aid box attached to a fender for a small tool box.
Lane Ranger
Slot hitch if you don't already have one.  A rear snowplow/tiller bracket.     Hex bolt head covers to reduce rust and exposure to elements.  New grease fittings.  New oil seals if needed.
jaxson stage
If you are talking attatchments i would highly recomend a tiller, snowblower and snowplow. These will pay off in the fall winter and spring!
SousaKerry
Oh yeah and do the lug bolt to lug nut conversion
rmaynard
A cup holder.
Forest Road
Magnetic oil drain plug from David Kirks Engines
Jeff-C175
A cup holder.
Bob, do you mean a BEER holder?  :scratchead:
Ohhhh, you mean for your red Solo cup?
Hydro
I found my axle mounted trailer hitch to be very handy.
glkssailor
Lots of ideas so far. I definitely need to spend some time on the wiring. I will use the plastic conduit where appropriate. I will also need to replace the current ignition switch. I will likely grab the ignition components off a Craftsman parts tractor. I will also see if I can find an hour meter to make tracking maintenance intervals easier... While I am thinking electrical I may add a 12v socket to run a small compressor I have, or spotlight.
I am planning to pick up some attachments as budget, time and good deals allow. I already have a disc and harrow set promised, and of course the dump cart. A snow plow or blower,  and rototiller would be handy.
I am fortunate to have the metal fenders on the C-105, and I very much like the idea of a small tool box, I currently have two small boxes that would be perfect for the job.
I will pass on the cup holder, I have generally found there to be too much vibration and rattling for them to be practical.
I have a bolt on box store hitch mount that is currently set up with a 1 7/8 ball for moving small trailers around the yard. It also has a hole for the standard tow behind accessories, and hooks for hauling with rope or chain. Unfortunately I have found that the ball is too low to be very useful with my trailers, so I will have to make a bracket to mount it up higher.
Speaking of rope and chain, a bracket to hang it on might be handy. I have a lot of brush to clear and will be pulling small stumps and roots. (wheel weights are in my future)
jeremi3210
I have a snap on can koozie with magnets in it. Works very will even with the unbalanced singles. And it fits any tractor with metal on it.
NCGT-14
a hot chick that doesn't mind mowing......right before the yard sale..........priceless.......
  • Similar Content
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Seat, New! Universal Garden Tractor / Riding Mower Seat
      This is a new seat that I purchased for a project tractor and never used, it is in Perfect as New Condition.
      I have used this seat on a few Wheel Horse tractors, and they have been a perfect fit and look great.
      This is a Universal fitment seat; it has multiple mounting holes and mounting patterns for fitment on most Graden Tractors and Riding Mowers.
      $49.00  Call Tim @ 1-313-460-8858     (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
      These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
      Great for any Garden Tractor or Riding Mower
      They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
      $99.00 Call Tim @ 1-313-460-8858        (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      C - Series, Hood and Sheet Metal (square black insert) (also known as black hood models) for sale!
      This sheet metal set, including C Series Hood, Dash piece, Seat Bracket, and Left & Right-Side Covers, and Left & Right Floorboards was sandblasted, epoxy primed, and painted the OEM Wheel Horse Red Paint.
      The painted set is not perfect, a little metal pitting on one of the floorboards, a few little imperfections in the paint here and there as I'm a rookie painter, but this is a nice painted set of sheet metal to freshen up your C Series Wheel Horse!
      $140.00 O.B.O. Call Tim @ 1-313-460-8858        (No Shipping, Local Pick-Up Only)
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
