clemedc
has anyone ever seen a RJ lift like this?
clemedc
I bought this RJ at the big show and I was wondering if anyone has ever seen a lift like this before? Does anyone know why its different?
post-7206-0-34556500-1373028837_thumb.jp
post-7206-0-49578100-1373028844_thumb.jp
buckrancher
Edited by buckrancher
clemedc
Ok thanks. Did you get my PM regarding pulleys?
Ride Away59
That lift lever was not modified its a original lift lever. A true rj59! I was the owner to that Ride Away Junior..
VinsRJ
Ride Away 59 speaks wise... that is an original lift indicator for a late 59 RJ...
clemedc
It looks to be Factory cut :confusion-scratchheadblue:
clemedc
Thanks VIN that seems to be a little known fact.
Clem
AMC RULES
We need a pinned thread to capture all them "little known RJ facts"    :twocents-twocents:
Seems there's a bunch of 'em.
Wheelhorsestory
If you read the Ride-Away Junior chapter in my book, you will find the answer to this question. This chapter is loaded with details in every sentence.
Yes, the member RideAway 59 is 100% correct. This is an original lift lever as it came on later 1959 models. It probably has the solid, wider seat, and fenders as well. This is a rare tractor that was a transition of sorts from the RJ58 tractors made in 1959. It is my belief that there are not many of this model, as soon thereafter the 1960 models were produced. After Cecil had to redesign the front axles, he made other improvements as well.  Please, please, please keep in mind that they're are not definite model year regularities until the 1960 model year.  Please don't go by casting numbers to determine a date of manufacture either. That has nothing to do with the date at all.  Although many will argue my facts, I am certain they are correct. This information was told to me by the man who made these tractors with his own two hands.
Great Post. I hope everyone is reading their book carefully(LOL)
Michael Martino
AMC RULES
If casting numbers are no help, and there are no "definite model year regularities"...
how does one go about determining the correct year of production.     :popcorn:
squonk
This is the supposed "59" RJ that I had last year. Looks like it may have had the same lift. Probably should have kept the little rascal! :no:
Wheelhorsestory
Great Question Craig,
The 1958 Ride-Away Juniors were the first Ride-Away Junior manufactured with the Uni-drive transmission. These continued to be manufactured through 1959. I have seen many, many variations as they used whatever parts were on hand. If you look up the date of manufacture from your engine's serial number and it states that it was made in 1959, it can not be a 1958 tractor.  The Ponds did not stock a huge amount of parts at any time, so I doubt if any 1959 tractors have an engine that was made in 1958, although there may be a few.  Wheel color, decals, etc. can not really be used for exact information.  In the DVD with my book, there is a video of the Pond family playing with a 1958 tractor that has black rear wheels. Why?  Because those were the rims that were on hand when it was made. There also were variations in the hitch style, rear axle hubs, etc.  The same is true of the tractors made in 1955-1957. I have even seen an original RJ58(not 1959) that had the decals from a 1960 tractor. The decal designer probably sent over some samples and the Ponds tried them out to see if they liked them. Now, the reason I say the casting number on the transmission can not really determine the year is simply because I asked this question of Mr. Pond and he told me that they did not cast anything to record the year of production.  I suppose the company who cast the transmission case could have cast the year of production on the casting, but as I said it was not something the Ponds ordered done.  I don't read too much into the early production years as some do. I am just happy to see someone enjoy their miniature tractor.
Thanks for this topic. I appreciate your interest in the historical aspect of year of manufacture. I am so happy to see such a great forum as Red Square. When I got into the hobby, there was absolutely no information about these little machines.
Enjoy every variation for what it is,
Michael
AMC RULES
Thanks for the quick reply Mike.   :handgestures-thumbsup:
So, taking your advise and having just read the RJ chapter...
I see one needs to be adept at decoding Kohler, Clinton, and Briggs numbers to be able to make the best educated guess.
Provided the tractor in question is still wearing it's original engine after all these years.
buckrancher
Sorry not buying it  you wouldn't double cut a part when you don't  have to ( waste of money)
If that part was made originaly to fit on a RJ 59 it would only be cut on the top side not on the bottom as the ponds were not making 400 surburbans yet
what that part tells me by looking at it. The cuts on the top side for The RJ was done after the fact ( as the part was originally made for the 400 surburban first then modified to
fit a RJ ) or a retro kit for owner dealer modifcation to the RJ lift
Brian
  • Like 4
clemedc
I think it's now safe to call it an original Wheel Horse RJ59 part.
clem
AMC RULES
:naughty:  I don't know Clem...Brian has a good point.
Having just looked through all the member picts uploaded into the pict gallery...
http://www.wheelhorseforum.com/forum/19-1955-to-1964/
I see none of the '60-'61 model Suburban's have their lift sectors notched on both sides.   :scratchead:
What's up with that, why is this the only one...so far?    :dunno:
wallfish
Brian
It also appears from the pictures that the spacing of the cut outs on the top are not spaced the same and not completely uniform which would indicate it was not done by the factory. But that could just be an optical illusion from the pictures or it was done on a Fri afternoon.
It could be possible that the 400 model was ready to be built as they neared the end of the 59 production and they just modified that 400 part to work on the RJ. Who Knows? Maybe the dealer didn't have the lift handle parts for the modification and came up with this solution?
I have one with a solid seat pan and the sector is welded to the hood stand and the frame but the holes are there for the bolts. Homeowner? Dealer? Factory?
This is the kind of stuff that makes it very interesting!
Edited by wallfish
Wheelhorsestory
You are right fellas, this is the kind of stuff that makes it very interesting!
Here is what we have as of now:
Fact:    Some later 1959 tractors had the muti-position lift sector
Unknown:  Was this particular individual tractor made this way at the factory or modified later?
Fact:  We will never really know.  All we have is our opinion.  My opinion is to enjoy it and believe what you want.
You guys get me so excited for even more research on the subject,
Michael  :banana-rainbow:
clemedc
Haha I enjoy the discussion anyway. Thanks to all who chimed in, it's a passion we all enjoy.
clemedc
As for the pics it is an illusion that I hadn't noticed, and all the cuts are uniform and not mismatch or unaligned. Maybe why some have thought its a home made cut
varosd
and Clay had it stored at my place after the show!!
"my" first RJ    (for 3 days, ha ha!)
What a cool buy! :D
rmaynard
Hmm...do I smell an addendum in the works?
AMC RULES
:text-yeahthat: LOL! So much for the final addition.
buckrancher
the side shot looks as some slots line up and others do not is from the differance from inside to outsde radis being if all slots have the same center line dim. on the
inside as the outside
Wheelhorsestory
I stand by my facts.  I believe this tractor is from the factory.  I simply tried to make a statement as not to cause an argument on Red Square since you can't convince some people. Read my post again.  My book is called Straight From the Horse's Mouth for reason.  It is FACT directly from Cecil Pond. There is no speculation.   This is the Final Edition and there is no need for an addendum when the information in the book is 100% accurate. Why do some people have to read into things or twist things.  My name is Michael Martino and I am the author!
  • Similar Content
    • CasualObserver
      By CasualObserver
      Operator manual
      Illustrated parts list
      6 pages 3.73MB
      Illustrated parts list #A-7136
      Includes PSB #023 #052 #058 #060 #080
      10 pages 938.48KB
      Engines used according to Toro
      Clinton B1290-1107
      Kohler K91-31307A
      Kohler K91-31388A
      Electric start kit
      Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
      Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
      6-12 tire chains model TC-12 - Listed for 1958 and 1959
      Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
      Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
      Details & Attachments
      2 pages 107.33KB
      1958 model RJ-58
      1958 serial numbers that have shown up for the RJ-58
      Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      00005
      00251
      01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
      01188 - Has round rear wheel hubs
      01516
      01636
      01768
      01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
      01797
      01871
      02525
      03177
      03501 - Located in UK
      03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      04041
      04883
      04885
      05000
      05619
      05714
      05798
      06528 - May be 16528
      06749
      06771
      07633
      07649 - Transmission J12-8 October 12, 1958
      07725
      08440
      08612
      09284
      09337 - Hard to read
      10163
      11432
      11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
      11916
      12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
      12291
      14473
      14713
      16097
      16528 - May be 06528
      166x6
      16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
      18348
      June 2023
      18500 and lower
      Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      2 pages 106.94KB
      1959 model RJ-59
      1959 serial numbers that have shown up for the RJ-59
      Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      18501 and up - Possible 1100 units built
      20078 - Located in UK
      203xx
      21033
      292xx
      21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
      Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
      K91T-31388A Serial 425251 found on RJ-59
    • bigbuck
      By bigbuck
      I'm not positive of the model, but I think I'm close. Please call George at 517-499-5678
    • RJcollector
      By RJcollector
      Ive been thinking about selling my 4 RJ-58s and all the attachments and parts I have. I have 4 tractors-2 have Kohler K91T , 1 has the Clinton and one has no engine. Only 1 is missing the serial number decal. Kohlers run. Clinton needs a carb. I have original exhaust shields AND belt guards for 3 of them. 3 mower decks, 2 plows, cart, 2 spare transmissions, parts breakdowns, original manuals and sale tags, seats, tires.  Not sure if I should sell it as 1 big collection or break it up. And also a good starting price?  I'll post pics when I get a chance. Thanks
    • wh315-8
      By wh315-8
      The RJ58 was the big hit for spectators this year at my local festivals here in Carroll County OH.
      the children loved getting their pictures sitting on it, then they discovered the bicycle horn under the steering wheel. It’s always a joy even in parades. Just love showing off part of my collection every year and hearing all the stories from those that had WH in their lives at one time. Can hardly wait to get to retirement so I can get some of my other models back to their glory in working order and be able to attend other shows/festivals throughout the year. My fellow tractor enthusiasts always know when a spectacular starts asking about WH, they point in my direction. I study up on the history of the different models and always intrigue those that didn’t know much about how WH came to be. This website is one place that has helped me learn so much about the WH history and I thank you for sharing your knowledge that I am able to pass on to keep WH alive and well.
    • Vaughan32850
      By Vaughan32850
      Has anyone got a WT-30 tiller they can send pictures if pleas? It’s the one fitted with a K91 engine for RJ models.
      Many thanks
