Austin860 82 #1 Posted June 30, 2013 Aquired this snowblower with a tractor, owner had not used the blower, only the plow. Said it worked and ran before he removed it. Is there anything I should check before running it so I don't break anything? Any additional info on this would be great, thanks Share this post Link to post Share on other sites
JamesBe1 84 #2 Posted June 30, 2013 Hmmmm. I would have to say that it would be a great idea to lubricate all of the moveable parts and hit any grease fittings you can find with a grease gun. Is there by any chance a gearbox? You might want to check the oil if that is the case. At the least, I would hunt down a copy of the manual on the internet. Other than that, they are pretty robust. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,605 #3 Posted June 30, 2013 Here are the D-Series except D-250 snowthrowers 6-7451, 6-7452, 66-48ST01, 76-48ST01, 86-48ST01, 96-48ST01, 06-48ST01 A 1973-74 manual Service bulletins that may or may not apply http://www.wheelhorseforum.com/files/file/1021-wh61-90-237-d-series-snowthrower-belt-jumps-offpdf/ Garry Share this post Link to post Share on other sites
Trouty56 567 #4 Posted June 30, 2013 There is grease in that gearbox.... Share this post Link to post Share on other sites
Austin860 82 #5 Posted July 1, 2013 Ok thanks guys! Share this post Link to post Share on other sites
