TurnerFarmsKS
Voltage Regulator on K181S - WH 855
TurnerFarmsKS
Hello!  I'm working to piece together a new wiring harness for my Wheel Horse 855...the old one was an absolute shambles so I started from scratch...the harness looks great and matches exactly to the wiring diagram.  The coil, condesner, spark plug, and points are all in good shape.
When I turn the key the starter turns over vigorously in the "on" and "start" positions, but the engines has no fire, whatsoever.
Here's the even STRANGER part... With the key in the "off" position, tapping the top of the voltage regulator gently causes the starter to turn the engine over...but again, no spark to the coil.
I really don't know a lot about the inner adjustments of voltage regulator...is there something simple I can adjust that might be causing this? Do I need a voltage regulator?
Thanks in advance for any input you can provide!
~Shawn
TurnerFarmsKS
gwest_ca
Here is a Kohler manual with a section on the starter/generator and regulator
Try cleaning the points with a point file or nail file. May be a bit of oxidation on the contact surfaces.
Garry
TurnerFarmsKS
That's a much better manual than any of the others I've been able to find...thank you!!
TurnerFarmsKS
Okay...reworked the wiring harness to include a solenoid, cleaned the breaker points and checked air gap in the voltage regulator...all seems okay. I have 12V to the positive side of the coil. The coil and condenser are new, the points are the same as new, clean, and gapped to .020, and everything is grounded. But still no fire...thoughts??
Martin
ignition in on position, ignition points closed, (or turn over engine by hand to get them closed), use a long screwdriver and open the gap at the points by pushing or prying on the frame of the points assembly, should get a nice blue spark to jump the point gap, if you dont points arent clean enough.
if all other ignition parts are in working order, once you have spark here it should fire.
what did you do to fix the regulator? if a slight bump closes the air gap and sends power to the starter you have problems there. its been a while since ive been inside a regulator for one of these, but from what i remember the air gap shouldnt be that easy to close and make contact. using the manual that garry supplied above you should be able to decipher whats going on there. i dont think adding a solenoid ( which in itself is a great idea- to get electrical load off the ignition switch) is going to fix the starter contact point sensitivity.........
gwest_ca
Remove the spark plug so you can turn the engine over by hand using the flywheel.
Stick your test light or voltmeter on the coil (-) terminal.
With the key in the run position see if you have power at the coil (-) terminal.
Turn the engine over by hand. When the points are open the light should be on or 12 volts. When the points close the light should go out or 0 volts. This alternates on and off with the points open and closed as you rotate the crankshaft. If it does not go to no light or 0 volts the points are not making contact electrically for some reason. They have to ground the circuit for the coil to work each time they close.
Let us know what you find.
Garry
TurnerFarmsKS
I used the manual Garry linked me to to take both sides of the regulator apart, clean the points, and re-gap them...it's in much better shape now!!  I think testing the points, which Martin & Garry both suggested is going to be be my best next step...I'll give it a shot and report back!! :)
Thanks!!
Save Old Iron
  • Similar Content
    • 2003Chevy
      By 2003Chevy
      Hello All!
      Added THREE tractors all at once yesterday(09/16/2025).  Two model 854, and one model 855.  The two 854 look pretty nice, but are not running right this minute  --does not look like much more than a little tinkering/refreshing after sitting for a long time.  The 855 was labelled a "parts" tractor, but except for it being Really well-used looking, it seems to be all there so I am not going to consider it out of play yet.  The two 854's have rear discharge mower  decks...one is a square style deck, the other the rounded style deck.
      I think it is really nice that all three are basically the same machine, separated by one year, yet completely different styles--the end of one era and the beginning of another I guess.
      There is an ID tag on the 855 (serial number 135166) but on the two 854 tractors, there is No tag under the steering like late models.  Are the tags in a different place on older machines?  Looking them over, I do not notice anything obvious.  The 854 with the lower Kohler engine serial number has the round style mover deck, while the one with the slightly higher engine serial number has the square style deck.
      All for now!  Be well and stay safe.
      [rayg]
    • WH1618speed
      By WH1618speed
      1965 Wheel Horse 855 with 42" blade and chains
      Runs good
      Sheet metal is very straight, great candidate for restoration.
      Missing Belt guard
      Will sell tractor by itself for $500 without blade and chains
      Blade is straight and lots of cutting edge left... just a little rusty.
      Text, call, or email with any questions. If you call and I don't answer please leave a voicemail with your name and number. Thanks!
      I can also deliver to the big show in Arendtsville, PA... IF you prepay.
      Facebook Marketplace link with more pics: https://www.facebook.com/marketplace/item/598023068755689?rid=229092436403311&ad_id&rt=1&refID=0&refType=0&referral_code=commerce_attachment
    • admin
      By admin-(Admin)
      1 page 196.25KB
      1 page 82.24KB
      Dated February 17, 1965
      232613 Kohler belt nla Use 231605
      232613 - Gates 7320 .41"x32.58" 36 degree or Napa 25-7320 .41"x32.58" 36 degree
      231605 - Gates 7315 .41"x32.08" 36 degree or Napa 25-7315 .41"x32.08" 36 degree
      1964 model 854
      1965 model 855
      1965 model 875
      Starter/generator belt
      Kohler 10hp, 12hp - 235262 (7345 Gates .410" x 35.09" 36 degree) (25-7345 Napa .410" x 35.09" 36 degree)
      Wheel Horse 1593 (3L x 34.4") - nla (Gates replacement 6735 3/8" x 35" 38 degree)
      1964 model 1045
      1964 model 1054 - Not in PSB - Wheel Horse # 1593 nla {3Lx34.4"} - Gates 7340 .410"x34.58" 36 degree or Napa 25-7340 .410"x34.58" 36 degree
      1965 model 1054A - Not in PSB - Kohler 235262 replaces 235528 [.41"x35.09" 36 degree] - Gates 7345 .41"x35.09" 36 degree or Napa 25-7345 .41"x35.09" 36 degree
      1965 model 1055
      1965 model 1075
    • DownHome
      By DownHome
      Looking for belt specs for my 855. Need to know which belt I need to attach from motor pulley to mower 36" mower deck. Thx
    • DownHome
      By DownHome
      I've noticed that while driving any sort of elevation change, whether it's up a hill or down I start losing throttle. What type of fuel delivery issues could I be having? Occasionally it will even die out almost completely. Sometime if I mess with the throttle I can get it back on track but seems like i shouldn't have to fuss with it that much? Any thoughts? Thanks in advance
