72raider
k181 governor problems
72raider
so I recently bought a 74 b80 guy says someone played with the governor and it just needed to be adjusted. so I tried to adjust but when turning it counter clock wise it never stopped. so I pulled the engine and took off the oil pan and there was the arm off the governor shaft and pieces from the governor gear. I have the gear all loose but I need to know if I need to remove cam shaft to get the gear out. or if there is a better way of doing it
oldredrider
You're gonna have to take it all down. Good time to do some measuring so you only have to do it once.
Since it's new to you, fix it right and you'll know what you've got.
72raider
measuring? I'm not to familiar with a tare down.
72raider
what is broke is the "wings" on the gear that the roll pins hold in. can those be replaced without removal?
MarkPalmer
You are going to need to completely disassemble the engine, including removing the cam, and replace the governor gear/flyweight assembly.
-Mark-
Fordiesel69
Remove in this order:
-Head
-Oil Pan
-Rod Bolts
-Remove piston / rod assy
-Flywheel
-Side plate
-Crankshaft
-Camshaft
-Gov Shaft
-Gov Gear.
Assemble in reverse order with oil hole in connecting rod facing the cam shaft.  Measure all your parts now that it is apart so you don;t have to do the job two times like I had to.
Most gov gear failures occur from someone holding the throttle open farther than 3600 RPM.
  • Similar Content
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
