SMITTY 23 #1 Posted June 11, 2013 Cleaned and flushed Transmission on my Lawn Ranger found one outside axle seal is leaking. Ordered new seals now have to find a good way to remove without taking trans apart. Not much metal to grab on to. Any ideas? Share this post Link to post Share on other sites
wallfish 18,428 #2 Posted June 11, 2013 try one of these. http://www.harborfreight.com/seal-puller-35556.html Or you can try to get a screw into it to pull on while prying with a small screwdriver. Share this post Link to post Share on other sites
SMITTY 23 #3 Posted June 11, 2013 That was my idea but didn't think I could get it in between the shaft and seal. will pick one up tomorrow. Share this post Link to post Share on other sites
SMITTY 23 #4 Posted June 11, 2013 just looked at reviews on HB tool will look elsewhere Share this post Link to post Share on other sites
Jeff-C175 7,206 #5 Posted June 11, 2013 You should be able to get a screwdriver in there... the metal is soft... start with a smaller screwdriver, bend the metal lip up to where you can get a bigger one in and work your way around prying with the screwdriver. It will pop right out. Clean the hub and axle up so that the hub slides easily and use that as a 'slide hammer' to drive the new seal home. Don't wail on it, just nice easy taps and the new one will go right in. Share this post Link to post Share on other sites
rmaynard 16,449 #6 Posted June 11, 2013 I use a 1/8" screwdriver with a hook bent into the tip. With the hook pointed toward the seal and away from the axle, I slip it in-between the axle and the seal. The hook will catch on the metal or plastic housing of the seal and then I yank it right out. That is easy to do with the 1" or 1-1/8" seals. The smaller ones like the 5/8" and 3/4" I use the same type of screwdriver, but without the bent tip. As mentioned by Jeff above, those I just pry out. Share this post Link to post Share on other sites
doc724 925 #7 Posted June 11, 2013 The newer seals (at least from Toro) are plastic with the rubber molded onto it. I simply push them onto the shafts (after putting scotch tape over the keyway of course. I Iearned that here on RS). Then I take a paint stirrer that I have ripped to about 3/8 inch wide (and sanded the end to make sure no sharp edges) and with a rubber hammer, gently tap it home. You will be surprised at the skill you will have in setting the seals. This may not work with seals that are metal, but it works fine for the plastic ones. Share this post Link to post Share on other sites
SMITTY 23 #8 Posted June 13, 2013 Thanks for all the suggestions. Bought a puller from NAPA to big a small Craftsman screwdriver and hammer couple taps came right out, new ones driven in with a piece of 1 inch PVC. Primed ready for some Red paint. Share this post Link to post Share on other sites
