Terry M
Tecumseh recoil spring install Problem
Terry M
While recently working on one of my older Lawn Rangers, I disasembled an early 60's tecumseh HH60 aluminum recoil for a cleaning . All looked good afterwards until it was time to put it back together.  My Problem is I can't get the spring reinstalled. spent two hours trying with no luck.
Is there a trick to reloading these recoils springs? or maybe some tool for the job?   Anybody done this before?  Or is this something I should have left well alone?
Any help appriciated.
WH nut
The way i do it, is hook the spring in the case and wind the spring to sit in the case. With the rope all hooked up, I then hook the spring to the rope pulley. I then get the pulley to sit inside the case where it belongs.. There should be a notch in the pulley. Pull enough rope through and set the rope in the notch and start wrapping the pulley to get the correct tension on the spring for recoil. I can do it quicker than it took to type this lol. Sounds complicated but its not really.
KC9KAS
A friend and I were discussing this just yesterday....If you still are having problems, send "LANE RANGER" a PM.
Terry M
Thanks, I'll try it again...Then I'll PM Lane if I fail at it again.
  • Similar Content
    • bigbuck
      By bigbuck
      I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
      please call George at 517-499-5678 for more info.
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
