WH854 44 #1 Posted August 15, 2008 Is the drive pully on an 8 Speed the same size as the drive pully on a three speed I have an 854 WH with a 3 speed tranny . I have an extra 3 speed tranny Iwas taking apart,but I broke The drive pully trying to take it off. I saw one one ebay for an 8 speed i was wondering if it would work Thanks for any help! Chas from Butler Pa Share this post Link to post Share on other sites
kpinnc 10,962 #2 Posted August 15, 2008 Is the drive pully on an 8 Speed the same size as the drive pully on a three speed Not neccesarily. Pulley sizes vary from one model to another. If you're switching trannies, and the tranny input shaft is the same size between the two, you should be able to just use both engine and tranny pullies. If not, list the model number of the tractor here. I'm sure we can help... Kevin 1 Share this post Link to post Share on other sites
TT-(Moderator) 1,129 #3 Posted August 15, 2008 3 speeds have a 3/4" input shaft. 6/8 speeds have a 5/8" input shaft. Most 3 speeds used a 4" diameter input pulley. Most 6/8 speeds use a (around 6 1/2" - but I forget the exact size) bigger pulley. There are a few exceptions. (like the B-80 4 speed/Commando 800 and the 867/1067/1267 models) If the engine pulley is 2 1/2 inch, the correct transmission pulley is 4". If the engine pulley is 4", the transmission takes the large pulley. If the engine pulley is 5 1/4", it is for a hydro. (875/876/877 are different though) 1 Share this post Link to post Share on other sites
WH854 44 #4 Posted August 15, 2008 Thanks TT for your help Chas from Butler Pa. Share this post Link to post Share on other sites
TT-(Moderator) 1,129 #5 Posted August 15, 2008 You're welcome.... and if I missed ya -- B) Share this post Link to post Share on other sites
kpinnc 10,962 #6 Posted August 16, 2008 3 speeds have a 3/4" input shaft. 6/8 speeds have a 5/8" input shaft. Ooops... Kevin Share this post Link to post Share on other sites
